low oil pressure
Old Sep 16, 2009 | 04:59 PM
halostryker's Avatar
Car: 84 Camaro z28
Engine: 305. LE9
Transmission: 700-R4
Axle/Gears: 3.42:1 Locking
low oil pressure
hey I got a quick question I just got my car back from getting the flex plate done and now when ever I'm driving and i hit the brakes to stop the oil pressure drops to the point that the car shuts off. I was just wondering Why and input will help thanks in advance.
Old Sep 16, 2009 | 05:19 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: low oil pressure
Is the engine low on oil?
Old Sep 16, 2009 | 05:50 PM
Car: 84 Camaro z28
Engine: 305. LE9
nope all of the fluids are full
Old Sep 21, 2009 | 05:10 PM
Car: 84 Camaro z28
Engine: 305. LE9
anyone? i really need to get this fixed!
Old Sep 21, 2009 | 08:53 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Are you sure the stalls/shuts off from low oil pressure? You could have a small vacuum leak that only becomes a problem when your using the power brake booster. My buddy had the same problem in his Fiero. If it isn't that I'd still think it would be somewhere along the lines of vacuum.
Hope this helps somewhat.
Alex
Old Sep 23, 2009 | 05:18 PM
Car: 84 Camaro z28
Engine: 305. LE9
i don't think it is a vacuum because I've redone the hoses recently, but I'm more trying to figure out why I have such a low oil pressure.
Old Sep 23, 2009 | 05:50 PM
Well, then I'd say your oil pump is worn out, or the oil pressure sensor is bad and giving a false reading/lying to the ecm. Can you hear the valves making noise?
Old Sep 23, 2009 | 08:41 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
For starters i would check to make sure your oil pressure reading is correct by checking it with a mechanical gauge. If it turns out you truly do have low pressure thats not the cause of say a plugged filter, low oil level, or something to that extent your motor is trashed or i should say in need of a rebuild at least.
Old Sep 23, 2009 | 09:26 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
you have a vacuum leak, contrary to the seamed popular belief around here, the oil pressure sensor for the fuel pump will NOT shut your vehicle down in a no oil pressure situatin, it is a nothing more than a bypass for the fuel pump relay. when you push your brakes, your brake booster exhausts your vacuum and the engine dies and your oil pressure subsequently drops to 0, what i would do to start is plug the line for the brake booster and drive around on standard brakes, the bladder in the booster probably ruptured. if she doesnt die, then you have a vac leak, most likely in the booster, if your booster ruptured i'dd pull your master cylinder away from it cuz that USUALLY is caused by brake fluid leaking past and into the booster
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
