stock tach not working. help please?
Car: 1984 camaro Z28
Engine: 5.0L H.O. L69
Well my tach used to go on and off. sometimes it would work, sometimes it wouldn't. I changed my ignition coil and it worked perfect for awhile but now it seems to not be working at all, not even occasionally. so what could be the problem with this? i know its not the gauge. i tried a new one and it acted the same. maybe I have a loose connection somewhere? im not sure. if you think you can help, just give it a shot. thanks!
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: stock tach not working. help please?
I am going to work on mine this weekend.if this idea works I will let you know.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
When you changed out the coil, you probably disconnected the wire for the tach. If it worked after you changed out the coil for a while, I would suspect that connection.
when i changed it is when it started working. and now it just stopped out of no where. I tried taking it out and putting it back in today to see if that would make it work. It did not. could i get a volt meter and check to see if the connector gives a reading?
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
My tach was reading wrong so I put 200k ohm resistors in and wah la it worked perfect today. Hope this helps,mine is factory tach.I found the info for resistors under tachometer search.
but mine doesn't work at all. And i tried diff. gauges and they did the same thing. when it does work it reads acurately.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
I really dont know what to tell you then,I thought it was just acting up.Hope someone else will come up with answer.Sorry I read your post wrong.
Car: 1985 Trans Am
Engine: 360
Your best bet would be to check the wire, and replace it. That's probably the simplest and cheapest thing to do first. I know my tach reads about 4000 rpms when idling, and goes way up as far as it will go when I barely give it some gas.
Thats what i was thinking to but its going to be such a pain in the ***.
as for your problem, Its the gauge itself with the problem. they need a resistor on there. you have to solder it on yourself. there a ton of threads about it and I think there might be a page about it in the tech articles section.
Genopsyde
Oct 7, 2015 08:35 PM
2000, 305, 3rd, 92, camaro, chevy, coil, generation, installation, iroc, problems, tach, tachometer, trans, working
