New Cam Help
Old Sep 20, 2009 | 10:48 PM
vjw757's Avatar
Car: 92 RS
Engine: 305 TBI
Transmission: AUTO
New Cam Help
Im looking at getting a cam for my 92z with a 305. I found a kit that looks pretty good. I'd like to know what you guys think and how much HP ill have after the upgrade.
http://www.summitracing.com/parts/CCA-K08-501-8/
Right now my 92Z has less than 40K original miles on it(see photo album). The only thing i have done to it is:
* Borla Cat Back System
* 22 Pound Injectors
* Race Chip
* TransGo Shift Kit
Other than that, Its a stock car. So how much HP will i be looking at?
Old Sep 21, 2009 | 12:20 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: New Cam Help
That's a fine choice, and I'd say do it, but your main bottleneck is the stock TPI base and runners, and those exhaust manifolds. Put those high on your list of what to do next. With this cam, you'll need to verify your retainer-to-seal clearance, and you'll need some new valve springs. Be aware that you have different exhaust manifolds than the optional Z28 engines. The TPI 305 with the T5 used the same exhaust manifolds as the 350, but your 305 didn't get those better manifolds. They're still about 35 hp shy of headers.
Old Sep 21, 2009 | 12:32 PM
vjw757's Avatar
Car: 92 RS
Engine: 305 TBI
Transmission: AUTO
Re: New Cam Help
Your saying if i get headers that will add 35hp. what do you mean by "main bottleneck is the stock TPI base and runners, retainer-to-seal clearance"?
Will the valve springs in the kit not work?
Old Sep 21, 2009 | 04:46 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: New Cam Help
you're connecting words that I didn't connect. retainer to seal clearance is a separate issue from the fact that those stock TPI parts are what is limiting your performance. First, you won't see much improvement in power from anything you do until you get some better-flowing runners and base. Second, and separately, I've had one of my third gen Camaros on a chassis dyno with the good manifolds, then again 3 days later with headers. The difference was 35 HP. Thirdly and separately from either 1 or 2, when you install a cam with lots of lift, like the cam you chose, you need to verify that when the valves are fully open, the retainers are not hitting the valve seals. Last, and separately from any of the above, I failed to notice that you chose a kit, I just looked at the cam specs, but those springs will work fine.
Old Sep 22, 2009 | 05:14 AM
vjw757's Avatar
Car: 92 RS
Engine: 305 TBI
Transmission: AUTO
Re: New Cam Help
What header did you use?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
