HELP!! How do I put this on??
Old Sep 29, 2009 | 06:08 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Ok, so I'm having a hell of a time putting a new pickup screen on my new oil pump. I tried putting a wrench on the flange and hitting it with a hammer, found this info out on the internet. Problem is I'm having trouble getting it started in the hole. I've got the screen in the freezer and am gonna try again with vasaline on it. Any other suggestions. Please I wanna drive my car
Old Sep 29, 2009 | 06:58 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Re: HELP!! How do I put this on??
I had to take a piece a sandpaper to the last motor i built with a stock pickup.
Old Sep 29, 2009 | 07:13 PM
Got it on, I froze it and smothered it with vasaline. PITA but I got it on. Once I get the position right I'll JB-Weld it so it never comes off again. Thanks for the input.
Alex
Old Sep 29, 2009 | 10:14 PM
One quick question, manual says to align the OP extension rod with the dizzy gear. I rotated and wiggled the pump until I got it flush with the block. Is there anyway that I can have the rod not aligned and still be flush. Just wanna make sure before I put everything back together.
Thanks!
Alex
Old Sep 30, 2009 | 09:04 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
just put the oil pump drive in with the pump. you can turn it from the dizzy hole.
Old Sep 30, 2009 | 11:04 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
yeah, with a long wide flat head screw driver. i used a hubcap pry/lug nut wrench from a chevy truck's jacking kit (only thing i had at the time big enough). i took a while and i was sad when i couldnt get the dizzy in the hole aligned. turned out the dizzy gear was reinstalled upside down. fix it. slopped right it. oh yeah gigadee gigadee
Old Oct 1, 2009 | 07:14 AM
Ok, but I never took my dizzy out. It cleared the firewall so I left it on. So I wiggled the pump until it went all the way in. Does this mean I have aligned? Or do I really have to take my dizzy off?
Alex
Jake_92RS
Jan 28, 2020 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
