AC, Heat all settings blow against windshield, not through vents
Old Sep 30, 2009 | 12:57 PM
halfmoontrail's Avatar
Hi and thanks in advance for reading this post.
I've been driving my '87 GTA almost daily since I returned it to the road a few months ago. 305 TPI/Auto, digital dash. I've charged the AC with R12, and replaced the blower motor.
It doesn't matter whether I select Max AC, Norm AC, Bi-level, or Heater...most of the air blows up against the windshield and not through the vents.
Any ideas for repair?
Thanks in advance,
Steve
halfmoontrail@yahoo.com
Old Sep 30, 2009 | 03:40 PM
1992_355's Avatar
Car: 1992 CAMARO RS
Engine: 355
Transmission: WORLD CLASS T5
Axle/Gears: 308
Re: AC, Heat all settings blow against windshield, not through vents
THE VENT DOORS ARE CONTROLED BY VACCUM,LOOK FOR A LEAK UNDER THE DASH OR BEHIND THE CONTROL PANEL .
Old Sep 30, 2009 | 03:47 PM
Thanks for your reply. Is the vacuum from the engine? Do I need to look under the hood, or from the pass. side, or the drivers side?
I appreciate the help.
Steve
Old Sep 30, 2009 | 03:57 PM
racethesunlive's Avatar
Car: '92 Camaro
I'm interested in how you fix this because I have the same issue with my camaro
Old Sep 30, 2009 | 11:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The vacuum line from the engine enters the firewall on pass side, just about where last spark plug is, close to edge of heater box - it is bundled there with the wires that control the fan on the heater box.
On the inside, remove the radio bezel, and then remove the heater controls - you'll see where the vacuum line runs into the heater controls, and where the heater controls 'sends' this vacuum through a round switch looking thing on the right hand side that has several vacuum lines in different colors coming out of it.
These are the places to look for the leaks.
Old Oct 1, 2009 | 08:25 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I've had problems with mine doing this, but it wasn't for lack of vacuum. From sitting for long periods of time, the damper doors get stuck. I was able to free mine by playing with the controls until it broke free. I now leave the controls in the vent position with the fan off so that the door has to operate every time I start the car.
Old Oct 1, 2009 | 08:58 PM
Richwiz1's Avatar
If you can hear a hissing sound when you move your selector switch you need to replace the round thingy as mentioned above it is called a selector valve part#16032395 your control is going to default mode. The valve controls what vent air comes out of.
Old Oct 2, 2009 | 08:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's what the selector looks like:
https://www.thirdgen.org/forums/atta...duct010707.jpg
A leak at the valve (or anywhere else )causes the default setting: defrost.
JamesC
Old Sep 19, 2010 | 09:08 PM
shanecosta's Avatar
I'm new to this site and need help locating this 16032395 vacuum selector valve for my '91 z28. I've tried to locate it variuos ways with no luck. Does anyone know where to purchase one?
Old Sep 19, 2010 | 09:43 PM
Richwiz1's Avatar
Autozone or any parts store should have it or try gm parts direct or napa. Just make sure u connect the right hose back to the right connection on th new one.
Old Sep 19, 2010 | 09:47 PM
Richwiz1's Avatar
If u have a pontiac it may go by a different part number
Old Apr 10, 2016 | 11:08 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
http://www.top-downsolutions.com/ind...category_id=67
I've begun refurbishing these GM 16032395, A/C HEATER VACUUM CONTROL VALVE.
Lon Salgren
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
chazman
Aug 28, 2018 03:25 PM
TheExaminer
Aug 26, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
