Oil Pressure Sending Unit
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Oil Pressure Sending Unit
Don't think that year had an in-tank fuel pump, so I think your looking for the sending unit for the guage, which should be in the china wall of the block, rear of the block, close to distributor on driver side of distributor.
Should look like these:
http://www.autozone.com/autozone/cat...&parentId=53-0
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Should be right by the distributor. There's an oil gallery hole right there on the back of the block they use. It's facing up so you should be able to look under the distributor and see it without too much trouble.
Ghettobird52
Jul 5, 2024 11:18 PM
ambainb
Apr 25, 2016 09:21 PM
