Gas line
Old Oct 2, 2009 | 03:02 PM
russ89gta's Avatar
Car: 1989 pontiac trans am gta
Engine: tpi 5.7
Transmission: th700r4
Gas line
Well, to make a long story short, I was attempting to remove the fuel tank from my car and ended up breaking one of the hard lines coming off the top of the gas tank (looks like the main one). My question is, can this be repaired or not? Thanks for your help.
Russell
Old Oct 2, 2009 | 04:04 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: Gas line
ive heard of people doing couplers, but id recommend a new fuel line. http://www.drclassic.com/catalog/Cam...el/S30009.html thats the return line, if you need the sending line http://www.drclassic.com/catalog/Camaro btw the way, the camaro lines work on t/a
Old Oct 5, 2009 | 09:31 AM
russ89gta's Avatar
Engine: tpi 5.7
Re: Gas line
Thanks so much! I may as well fix it right while I've got the tank out.
Infested
May 22, 2018 11:56 PM
Strick1
Aug 27, 2015 08:57 PM
Dialed_In
Aug 20, 2015 01:45 PM
AkDrifted
Aug 17, 2015 07:45 PM
wayshegoes
Aug 17, 2015 12:00 PM
