need help to identify
Old Oct 5, 2009 | 10:11 PM
1984_350_lt's Avatar
Car: 84 z28
I pulled this motor out of a 96 pu. The owner said it was'nt the factory engine, but he wasnt sure what it was. It ran fine, no knocks but smoked like a train. The casting numbers are 10243880
thanks
Old Oct 6, 2009 | 01:21 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: need help to identify
thanks
Front of the block , pass side is a pad with letters stamped in it.That will tell you exactly what size / Hp / trans the engine was originally. Block casting means little as one casting may have been used for several different engines
10243880 lists as a 96-00 block 1 pce seal roller cam block. Could be Vortec truck ( 2 or 4 bolt mains), could be ZZ4 or a GMPP crate engine. Same block used
Pull rocker covers and see what the heads casting # are
How many bolts holding the intake down?
Old Oct 6, 2009 | 01:30 AM
Car: 84 z28
head casting numbers are 14102193
Old Oct 6, 2009 | 01:39 AM
Car: 84 z28
Ok I'm kinda dumb when it comes to identifying engines by numbers and letters how would i go about decodeing in lol
Old Oct 6, 2009 | 02:37 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If stock block and not machined should have 3 letter code as well as some numbers stamped on the pad.
Google the 3 letters or post up here
Old Oct 6, 2009 | 02:43 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/tech...tyle-head.html
https://www.thirdgen.org/forums/tech...der-heads.html
https://www.thirdgen.org/forums/tech...4102193-a.html
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
Tweeks25
Sep 17, 2015 08:04 AM
abrilnelson89
Sep 16, 2015 02:19 PM
angel2794
Sep 8, 2015 06:22 PM
