Another Cam question...
Old Oct 8, 2009 | 06:05 PM
dgnretj's Avatar
Car: 1987 iroc z
Engine: 357tpi
Transmission: t5
I was originally going to order the cc503 cam... but i contacted COMP Cams and they recommended their part number 07-467-8 ... i have a 350 bored .040 over with edelbrock 60859 heads, TES Headers, 1.6rr, and HSR. the problem i see is for my heads the max valve lift is .575, and the 07-467-8 cam with the 1.6rr will make it .576... will this be a problem? ill post cam specs below... thanks guys
cc503:224 int./230 exh. @050 0.503 int./0.510 exh.(1.5) lift 112LSA 1,800-5,800rpm
07-467-8: 230 int./236 exh. @050 0.576 int./0.570 exh.(1.6) lift 113LSA 2,000-6,000
Old Oct 8, 2009 | 06:21 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Another Cam question...
I don't think .001 extra will be a problem
I assume you mean the max is what the springs are rated for.If you want to run higher lift need to change the springs
Old Oct 9, 2009 | 03:55 PM
dgnretj's Avatar
Car: 1987 iroc z
Engine: 357tpi
Transmission: t5
yes that what i mean... im actually going to change heads to afr 195s but thats a few months down the road... thanks for your input.
Old Oct 9, 2009 | 04:54 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
bear in mind that the hydraulic part of the lifters will eat about .004" of your advertised lift, so your actual valve lift will be more like .572" anyway. And that is with 1.6:1 rockers, I do believe.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
