std bore 400 compresson problem
Old Oct 13, 2009 | 04:09 PM
5.0slayer's Avatar
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
ok im building a std bore 400 i want to fun forged pistons and have low compression and i have 60cc heads,
the question is is there a place that sells thes pistons in a dish
or can i use pistons for a 5.7 rod on the stock 5.565 rod to get a taller piston to deck witch in return will do the same as a dish piston and then run a 350 crank like a 377 just not .030 over, so that will make a 372cid with atound 8.7-1 to 9.6-1. ive done plento of searching and cant find nothing,
to me it seems like it should work fine, just want a couple of opinions b4 i spend my money, and there should b no clearance problems because of the shorter stroke.
Old Oct 13, 2009 | 04:47 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: std bore 400 compresson problem
What CR you looking to get ?
Your small chamber size is going to limit you as the normal 22-26cc 400 piston dish gives about 8.5 with a 76cc head.
JE # 232514 has a massive 36cc dish and still gives 8.7 on a 60cc head using 5.7 rod.
Head change would be cheapest option to lower CR
Old Oct 13, 2009 | 04:56 PM
5.0slayer's Avatar
Car: 91 camaro RS
im lookin to run about 10lbs on the 400
but yhe question is can i use pistons for a 5.7 inch rod on a 5.565 rod the piston sits farther from the head and will give me more compression room in return it will lower my compression, its a very tight budget build, and the heads have crazy money in them from my 350 i had b4 this
Old Oct 13, 2009 | 04:58 PM
5.0slayer's Avatar
Car: 91 camaro RS
and i really think thar 800 is to much for what im willing to spend on pistons i would rather gey a used set off of here for 160 and get it bored then spend that
Old Oct 13, 2009 | 06:42 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I didn't suggest buying them ; just an example of the CR with a 36cc dish on your 60cc head
question is can i use pistons for a 5.7 inch rod on a 5.565 rod .. in return it will lower my compression,
Yes but you end up with some crazy numbers
1.560 CH ( stock 400 w/ 5.565 rod ) to 1.425 CH ( 400 piston for 5.7" rod ) difference is .135" .Add the 0.025 block deck height and you have a quench of 0.160 without a gasket!
Google "quench height " and see how important quench is in preventing detonation especially under boost
Better price
http://www.summitracing.com/parts/STL-H615CP/
Old Oct 13, 2009 | 06:55 PM
5.0slayer's Avatar
Car: 91 camaro RS
i was told to only run forged pistons for boost,i did the research b4 i asked ad with a 5cc dome it was a 9.6 to 1, i mean i can make up some compression if i just used domed pistons rite?
or just used the stock 400 crank and made it up there
Old Oct 13, 2009 | 07:06 PM
5.0slayer's Avatar
Car: 91 camaro RS
ok i looked and with 7.8cc domed piston and the 350 crank and 60cc heads with 5.565 rods its 9.3-1 on 3 different calcs
http://www.summitracing.com/parts/TRW-L2311F/
these r for 5.565 rods and useing them on a 350 crank will give me the same CR, would this work?, and is it safe to boost a 372 with cast 350 crank
Old Oct 13, 2009 | 08:21 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I wouldn't because 372 is a revver
Ask the guys over in 3rd Gen Power Adder, what CR you can run with what boost first
https://www.thirdgen.org/forums/power-adder/
Then you can work back to see what pistons will give you the right CR. Just guessing otherwise.
C409
Sep 23, 2015 04:30 PM
mddaniel
Sep 8, 2015 05:16 PM
downsouthboy
Aug 29, 2015 11:29 AM
neekolzun
Aug 24, 2015 04:59 PM
NinjaNife
Aug 23, 2015 11:49 AM
