INTAKE GASKET REMOVAL
Old Oct 21, 2009 | 09:36 AM
MADMAXGTA's Avatar
Car: 89 TTA
ok,these 89 oem lower intake gaskets are on solid,what the best way to get these off? there tough bastards i dread plugginf al the holes and die grinding them off.
Old Oct 21, 2009 | 09:41 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: INTAKE GASKET REMOVAL
find a stiff knife in your kitchen and use that. Seriously. I do it a few times every month. Serrated blades can be helpful, but until you have some practice, they're more likely to do harm to your parts.
Old Oct 21, 2009 | 10:20 AM
MADMAXGTA's Avatar
Car: 89 TTA
Got a gasket removal tool for napa,looks like a long pry bar lol,they came off with ease tapping the tool along pealing them off in as much of one pice has possible,to save myself some work,i got 95% off in 15 mins
How ever ther is some thin material wher i didint get completely under the gasket,keep scrapping i guess? or ????
Old Oct 21, 2009 | 10:32 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
There are wire brush things that you chuck into a drill, those are okay. Don't use the abrasive pad style, they'll leave you with a leak point when you reassemble everything because they'll eat into iron.
Old Oct 21, 2009 | 01:25 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
I use a heat gun on really stubborn ones. It softens them up.
Old Oct 21, 2009 | 05:08 PM
MADMAXGTA's Avatar
Car: 89 TTA
Covered the bock with rags,plugged the holes on head with rags,lol taped a shop vac to a drill,used a wire wheel and wow it worked great! sucking up most debre has i went along, the thouroguhly cleaned and shop vacced every crevis for any debres of gasket,I will flush my oil and coolent system after this stealth ram is installed,thx for the guidence.
http://img27.imageshack.us/i/picture11013.jpg/
Old Oct 23, 2009 | 09:48 AM
MADMAXGTA's Avatar
Car: 89 TTA
Think cleaning inside the intake ports with a wire brush is a good idea? thers alot of carbon build up..idk
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
theshackle
Aug 22, 2015 06:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
