im confused and in need of help!
Old Nov 1, 2009 | 05:24 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
88 lo3 , i did an upper engine rebuild after a blown head gasket " new seals on valves " , after putting it back together it ran rich , so i brought it home and tried to find out what it was , later i found out that my drivers side exhaust manifold was loose and so i tightened it and that fixed the problem for a little bit , the problem came back as soon as i set my timing to 0* TDC , ever since then i cant get the white smoke to go away , i was getting a couple of codes " one wich was a coolant temp sensor " so i replaced it and now i have no codes , and still runs rich , i have gone through 2 oxygen sensor because of the rich condition , i dont know what else to do , im not an expert mechanic but i am willing to give it a try , what else could it be , i have no SES light and it runs like crap , i even tried advancing the timing " since im running 91 octane" and it ran worse , what else could it be ? could some sensor have got messed up after running so rich for so long , any suggestions?
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
