Head Gaskets for correct quench
Old Nov 10, 2009 | 06:01 PM
shuanm's Avatar
Car: 84 Z28
Engine: Stealth Ram 355
Transmission: Borg/Warner T5 WC
I have a friend that owns a machine shop, but it isn't the type of machine shop that rebuilds engines. I borrowed a depth caliper from him and found out that each of my pistons are .030 to .031 down the bore. Should I use a felpro 1094 with a .015 compressed thickness, or is there a better gasket that I should consider to get my quench correct? I intend to use this for a street car and don't know if quench is important for that, but would assume it would be to reduce detonation..
Old Nov 10, 2009 | 06:07 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Head Gaskets for correct quench
Quench is very important especially if you are running a decent CR.
http://racingarticles.com/article_racing-10.html
http://www.camaros.net/forums/showthread.php?t=124935
http://www.popularhotrodding.com/tec...eze/index.html
Old Nov 10, 2009 | 08:03 PM
shuanm's Avatar
Car: 84 Z28
With the 1094 it should be around 9.9:1 static with my speedpro h345ncp pistons and 67cc Iron Eagle SS heads. Is the felpro 1094 a good gasket for this application, or should I go thicker and lower the CR a little? Will those gaskets hold up to daily driven? Maybe 10K to 15K a year??
Old Nov 11, 2009 | 09:10 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The 1094 gasket will be fine for every day use.
Old Nov 11, 2009 | 04:21 PM
shuanm's Avatar
Car: 84 Z28
Thanks a lot for the help. I will get those on the way, and get my Z back on the road.
Old Nov 12, 2009 | 04:11 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
It has been suggested on here to spray copper spray-a-gasket on both sides of the 1094 before installation to help with the sealing.
I did and have had no issues with leakage.
Just food for thought.
Old Nov 12, 2009 | 07:09 AM
shuanm's Avatar
Car: 84 Z28
I thought the 1094 had a rubber coating. Do you spray it over that?
Old Nov 12, 2009 | 10:39 PM
shuanm's Avatar
Car: 84 Z28
Hello?? Do I just put the copper over the rubber coating that comes on it?? I've never used steel shim gaskets before.
Old Nov 13, 2009 | 04:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Yes.
Added security.
Remember, technically you're supposed to have perfectly flat surfaces to use this shim gasket or it won't seal.
Old Nov 14, 2009 | 07:54 AM
shuanm's Avatar
Car: 84 Z28
The one I took off was a steel shim. All of the others I saw were way too thick to get a decent quench. Should I throw the quench idea out and use a .039 thick gasket? I just want to do the right thing.
Old Nov 15, 2009 | 06:02 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Do the right thing and shoot for quench.
Old Nov 19, 2009 | 05:40 PM
shuanm's Avatar
Car: 84 Z28
Thanks for the info.
Old Nov 20, 2009 | 10:19 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
If you had a steel shim before and you had no leaks, you should be fine, but typically you'd put a long steel straight edge across your heads and use a .002" feeler gauge and see if you find any dips. Might be worth verifying first?
Old Nov 20, 2009 | 04:08 PM
shuanm's Avatar
Car: 84 Z28
Oops. No one suggested that yet. They are on now, so I guess I'll just have to hope for the best. It was a crate engine and came with steel shims, but I bought brand new heads. I'll know in a couple of days. I'm not scared to do it over again though.
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
NWAsonoma
Aug 18, 2015 05:45 PM
