Torque arm mounting bolt
Old Nov 17, 2009 | 03:53 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
I was looking for the thread that was started trying to find all the different bolt sizes for these cars but couldn't find it. I need to find out the size of the bolt used to hold the torque arm mount onto the tranny. Not the two that hold the main part, but the one bolt that holds the removable piece of the mount. Any help is appreciated, thanks guys.
Old Nov 18, 2009 | 01:01 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Torque arm mounting bolt
Don't know what it is off the top of my head, but it would probably just be easiest to find one in a boneyard. It's a high grade (10.9?) metric, not easy to find in a hardware store. You don't want to take the chance of it breaking on you while you're driving
Old Nov 18, 2009 | 02:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.spohn.net/shop/1982-1992-...dware-Kit.html
Old Nov 18, 2009 | 11:36 PM
That's not what he's looking for is it? He needs the bolt for holding the torque arm onto the tailshaft, where the bushing is. There are 2 large bolts on bottom and one relatively small one on top of the bracket, that "clamps" the bushing together so to speak. That's what he needs, not the bolts on the differential, assuming I understood him correctly. I've never seen it for sale new
Old Nov 18, 2009 | 11:48 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Any bolt you need they have.
http://www.fastenal.com/web/home.ex
Old Nov 19, 2009 | 12:28 AM
84Z28406's Avatar
You are correct, Primetime91. As for finding one in the junkyard, F-bodies in the U-Pick yards are like hens teeth. I thought I hit the jackpot this year because I found not one, but two. Both V6s and both stripped clean.
Old Nov 19, 2009 | 01:42 PM
five7kid's Avatar
You're right.
Try looking through/asking on the Classifieds forum. People who have converted to crossmember mounted torque arm may have their old part available.
Old Nov 19, 2009 | 03:17 PM
The thread is M10 x 1.5, with 1 3/16" under-head length. It's a grade 10.9, which I think is the highest metric grade
Old Nov 19, 2009 | 11:13 PM
84Z28406's Avatar
:O You're my new favorite person ever! Thanks man... To the store tomorrow! I've bought about a dozen random metric and standard bolts over the last couple weeks.
Old Nov 20, 2009 | 01:12 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
When I got my car put back together, I guess I didnt snug it down enough and it backed out on me after a few hundred miles....
Was halfway to a friend's house and heard something clanking around under the car as I shifted into 2nd... immediately let off and everything felt okay... let the clutch back out and started again and I hear a loud CLANK near the shifter. Then it seemed fine for a little while.... everytime i'd slow down, it would clank. Then after speeding up it would clank. Sharp turns? Clank....
It took me a couple of miles to figure out what was going on. But fortunately GM designs those mounts so that you can lose the top bolt and the torque arm wont fall out of the car.
Anyway... I'd suggest some loctite on that damn thing. It's a pain in the *** to get to.
Old Nov 20, 2009 | 10:51 AM
Definitely use loctite. And for those of us with T5's (Yay ) the bolt isn't that difficult to get at if you remove the center console and shifter, or the shifter boot anyway. But talk about a bitch to get at from underneath the car...
Old Nov 21, 2009 | 02:36 AM
84Z28406's Avatar
Yeah, it sucks trying to get from under the car. Luckily I haven't put the shifter boot back in yet, so I'll get it topside tomorrow.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
