Oil leaking from valve cover??
Old Nov 20, 2009 | 11:56 AM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Hi i have a 87 iroc with a 305 tpi...My problem is i was cleaning it today and i opened the hood and my valve covers has oil on the top not like heavy oil but like its leaking and on the sides there is also oil...i wanted to know if it can be the valve cover gaskets so i can replace it.. thanks
Old Nov 20, 2009 | 03:37 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Re: Oil leaking from valve cover??
When I bought my car, I decided to clean the engine. I noticed old oil underneath the TPI intake and liquid oil on the valve covers. I wiped off oil on the valve covers and haven't noticed any more leakage. Keep an eye on it and see if more oil appears. You can then replace seals. New seals aren't too much anyways.
Old Nov 20, 2009 | 04:31 PM
Engine: 350 tpi
well i cleaned them before and it came back so i wanted to know if that can be the only possible reason its leaking like i noticed it on my manifold too.
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
