got the GTA weighed.....
Old Nov 20, 2009 | 12:02 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
well my gta weighs 3620 with me in it..... so its 3450 without me.. thats with 60 percent of gas and a full sub system in my car and two sets of sfcs installed on my car.... how does my car weight sound... lve deleted a ton of thing under the hood... i knew these gta's were pigs but i didnt know they were that heavy...
Old Nov 21, 2009 | 05:37 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: got the GTA weighed.....
IIRC the GTA's were 3456lb from the factory.
I still need to weigh mine but i'm thinking it's somewhere in the neighborhood of 3300lbs.
Old Nov 21, 2009 | 06:05 AM
Damon's Avatar
GTAs were generally the most "optioned up" model of the Firebird you could buy. Yes, they're fat.
But look on the bright side.... a new '10 Z28 weighs almost 600 lbs. more than your GTA! So your GTA is a featherweight compared to one of them.
Old Nov 21, 2009 | 07:36 AM
skinny z's Avatar
Fully optioned 86 IROC w/ all ac equipment removed and glass hood: 3450 lbs w/ half tank of fuel.
Old Nov 21, 2009 | 07:40 AM
88fastgta's Avatar
the thing is that i remove about 150lbs from the car last year with all the ac and smog and the spare tire and lightweight engine parts..... im 6'4" and 170 pounds...... i guess my tpi must have a ton of power because it moves that tank pretty quickly.... for the weight of my car i really cant complain of the power that i have..... if i had the weight of some of these light imports i would have a super quick tpi...... i know if i swapped my engine and transmission into a fiero i would be much quicker
Old Nov 21, 2009 | 09:13 AM
RockinGTA89's Avatar
Car: 1989 GTA Trans sold :(
Engine: 350 TPI L98 (B2L)
Transmission: TH700 R-4
So i guess it's true..don't believe what the door sticker says about these cars..
as stated on my identification sticker, it states that F weight is 2177lbs and rear weight is 2100lbs...which makes it a total of 4277lbs! At first i believed in that number but then i keep thinking "are they really that heavy??"
88fastgta, if your car weights 3450, then i assume my 89 is around the same thing only i a lil heavier since i still have the stock rubber spoiler and i have ttops as well...i hear that hard tops are lighter then ones that have ttops...interesting numbers though...i'm sure we can make these cars lighter with few mods to them...
Old Nov 21, 2009 | 09:17 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Any weight listed on the car is most likely gross vehicle weight, as in what it should weigh with full cargo/passengers and really isnt a good gauge for actualy vehicle weight.
Old Nov 23, 2009 | 12:43 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Yeah, that's your maximum gross vehicle weight, not curb weight.
Old Nov 23, 2009 | 06:17 AM
88fastgta's Avatar
im still not done with the car... i still have the stock rubber wing thats busted up... im going to get a fiberglass remake..... then i might switch to corvette aluminum heads to shave about 60-70 pounds total off the car making it under 3400 pounds...
Old Nov 24, 2009 | 09:56 PM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
you will only save 45lbs with the switch to aluminum heads. And why waste money on those heads? Better can be had for the same cost.
...Unless you can get 'em for less than $300 and can do some killer port work yourself..
Old Nov 24, 2009 | 10:43 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Mine with T-tops. jack, spare tire, aluminum heads, shorty headers, dual cat system weighed in at 3510 pounds. Maybe 1/3 tank of gas. I have since done some weight reduction and hope to get down to around 3430.
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
