Been away from my car for a while suggestions on gaskets and seals
Old Nov 26, 2009 | 08:01 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Hello,
I havent been near my car for quite a while and after starting it it looks as if the valve seals might be done for and i noticed my HSR intake had some coolant on top of it which makes me think the intake gaskets are shot, i have AFR 195 heads which gaskets and seals are best (i dont know anything about them), i was reading about viton seals ?
thanks
Old Nov 30, 2009 | 01:10 PM
91Z28's Avatar
Car: 91' Z28
Re: Been away from my car for a while suggestions on gaskets and seals
TTT
Old Nov 30, 2009 | 10:52 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
You definitely want to go with Viton valve stem seals. I would also highly recommend that you go with Fel-Pro for all gaskets and seals. With aluminum heads I would use the intake gaskets in the link below.
However, this is jsut my opinion. I jsut got through building my engine and learned a lot myself.
http://www.summitracing.com/parts/FPP-1205/
Old Dec 1, 2009 | 12:23 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you sure it's not wicking up the intake bolts?
Old Dec 1, 2009 | 03:00 PM
91Z28's Avatar
Car: 91' Z28
You know i never really thought of that, it's a possibility, what should i do in that situation ? Are there any brand of viton seals that are better than another ? Thanks guys !
Old Dec 1, 2009 | 03:22 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Looks to me like everyone and their brother makes valve seals. I would suspect that getting them from any of the 'big name' valve train component manufacturers would be a safe bet.....
I would also wonder about the advantages of Viton, over Teflon seals......
Old Dec 1, 2009 | 04:05 PM
wildjyoung's Avatar
I used to work in an Engineering Department for a while and we did a lot of testing on seals. Viton and Kalrez lasted dramatically longer and we had far less leaks with them. The were superior to Teflon is high pressure/temperature situations. Kalrez was even better the Viton but is too expensive and I have not heard of anyone making valve stem seals out of kalrez.
Old Dec 1, 2009 | 05:05 PM
ploegi's Avatar
Engine: 5.7 TPI
Oh? Very good information. Thank you very much.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
