lost my keys
Old Dec 5, 2009 | 11:31 AM
86firebirdta's Avatar
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
lost my keys
got a new ignition cylinder and i cant get the lock plate off any help
Old Dec 5, 2009 | 12:26 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: lost my keys
Auto parts stores rent lock plate removal tools. Usually you pay a deposit and then when you bring it back you get all your money back. Autozone, Schucks, oreilly's have them for rent. I use one so much I bought one to take with me to the wrecking yards.
Old Dec 5, 2009 | 01:23 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: lost my keys
Yep you are going to need that tool to take the plate off and put it back on. They are pretty cheap actually, I just bought one to save the trouble of renting it.
Old Dec 7, 2009 | 04:47 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: lost my keys
If you dont want to buy the tool you can build your own.. I did it, I will quote my post from another thread intead of writing a new one
Originally Posted by Theking
You need an Steering Wheel puller and a Lock Plate Depressor,
Star by removing the bolts and horn button.
Steering wheel removed, and the Lock Plate is showing
I built my own Lock Plate Depressor, as shown below:
Remove the locker ring
Lockplate gone. Remove all loose things, and photo to remember how it was assebled
The black bolt is for removing the ignition lock cylinder
You dont have vats so you wouldnt have the wire into the lock cylinder, Just turn the lock cylinder clockwise (i think it was) and remove it, install the newone turning it counterclock wise and insert bolt and then check to see if it turns ok.. if it does assemble everything, if not, adjust the lock cylinder.
You got more pictures from my change of the ignition lock cylinder : http://theking.joakimweb.se/z28/proj...nitionlock.htm
Its in swedish but you see the pictures, hope this post help you out.
So thats another way to go if you dont want to buy the tools, cheap and worked the same way
QUOTED Thread: https://www.thirdgen.org/forums/tech...placement.html
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
3.8TransAM
Sep 27, 2015 08:37 PM
