my '84 camaro wont start!! help!
Old Dec 8, 2009 | 09:19 AM
TheREVOLUTION22's Avatar
Car: '84 Z28, '06 Scion tC
Transmission: auto
ok so my car needed belts. they were squeaky. and i dorve one night and the belt tore and i didnt know. the next day tried to startit. well no belt. no start. i got a new one put it on. wouldnt start. sparks flew when i hooked the battery to jumper cables.
i figured there was something with the starter. replaced the starter. put a new battery in it. and all it does when i turn the key is a light clicking noise. and i have no power to anyting. no lights stereo. nothing. well then i looked at fuses. and the first one i pulled out was burnt out. could this be my only problem left?
Old Dec 8, 2009 | 09:37 AM
whitefirebird's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: auto trans with overdrive
Re: my '84 camaro wont start!! help!
clicking usually means your battery is dead.check your battery charge and all your fuses
Old Dec 8, 2009 | 12:24 PM
Transmission: auto
well yeah i said that im thinking its fuses. i know for a fact my battery is not dead i just took my dead one back and got a brand new one yesterday. thanks
Old Dec 8, 2009 | 12:48 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
i have that same problem tell me what fuse you swap to get it running so i can do the same
Old Dec 8, 2009 | 01:06 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Just replace them if they blow, I dont think you need to know which one is making you have that problem, if its blown, replace it.
Old Dec 8, 2009 | 02:14 PM
Transmission: auto
yeah thats what im doing. im just gonna go through all of them and replace the blown ones
Old Dec 8, 2009 | 02:15 PM
Axle/Gears: stock
yeah well thats my problem i cant find a blown one where is the engine compartment fuser box
Old Dec 8, 2009 | 02:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are no fuses in the start circuit.
Since you don't have power to anything, one of two things happened: 1) The fuseable link for the chassis power has blown; 2) the chassis power wire didn't get hooked up when you replaced the starter - it goes to the same starter terminal as the positive battery cable.
First make sure no wiring got torn when the belt failed. Not too likely, but you need to check.
For sparks to fly when you hooked up the jumper cables, one of two conditions had to exist: 1) You had the jumper cables on + on one battery and - on the other battery; 2) there was a hot wire shorted on the car somewhere.
Old Dec 8, 2009 | 04:02 PM
Transmission: auto
ok five7kid.
umm i know for a fact the cables were hooked up right. and youre saying that one of the wires has to be hooked to the same terminal as the battery?
i have three terminals 1) battery 2) S 3) R
there is two wires going to one eyelet and the other is just one wire.
i have the double wired one to S and the single to R
i just switched out the fuse and it didnt work. but we crossed over on the starter and it turned over so we do know it is a wire.
so youre saying if i hook up the double one to the battery is it going to work, right?
Old Dec 8, 2009 | 05:03 PM
five7kid's Avatar
The purple wire with the small eyelet goes to the "S" terminal.
The red wires with the large eyelet goes to the same large terminal as the battery cable.
Old Dec 8, 2009 | 05:22 PM
Transmission: auto
ok that helps alot!
just all my wires are black. but i know what you mean thanks
Old Dec 8, 2009 | 06:05 PM
five7kid's Avatar
Clean them off. A little WD-40 on a rag will do.
Old Dec 8, 2009 | 06:15 PM
Transmission: auto
ok lol
Old Dec 8, 2009 | 08:25 PM
Transmission: auto
started up on the first try! thanks man.
tomorrow header goes back on and y pipe get bolted on. and drifting here i come...
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
