Rod bolts, resizing rods.
Old Dec 9, 2009 | 09:42 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
i heard someone talking about this for there sbc, apparently theres some that are the same length and weight as the stock ones yet net a PSI strength rating like ARPs 200,000 and don't require resizing the rods.
anyone like to elaborate on this?
Old Dec 9, 2009 | 10:05 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Rod bolts, resizing rods.
Why would bolts require resizing the rods? Generally, I always thought "resizing" referred to making sure the crank journal was the right size.......
Old Dec 9, 2009 | 10:15 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
the arp wave lock bolts require resizing because they fit so tight that they can cause a slight bulge in that area. i've run the arp stock replacements without resizing with no problems
Old Dec 9, 2009 | 10:58 PM
ploegi's Avatar
Engine: 5.7 TPI
Thank You.
Old Dec 10, 2009 | 06:19 AM
FueledSoul's Avatar
with new bolts the cap won't line up exactly how it did before and the rod will be out of round this is what iv heard. it even says on arps install sheet
"rods resized. This procedure is recommended any time rod bolts are replaced"
Old Dec 10, 2009 | 05:08 PM
FueledSoul's Avatar
Old Dec 10, 2009 | 07:15 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
This sounds about right. Its always a good idea to at least have the rods checked for roundness when new bolts are installed anyway though.
Old Dec 10, 2009 | 07:52 PM
Guest
Guest
Posts: n/a
The bolts are pressed in and are close enough to the rod bore that it could distort the bore or have a slight alignment change on the cap. Its more likely to have a bore distortion than anything. I've heard some people say you can just swap them out no big deal, but I'd at least have them checked.
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
