changing 2 rods in rebuild
Car: 88 iroc
Engine: 350 bored .40 reman vortec heads
we are rebuilding a 350 I have a new recond. crank what i would like to do is take 2 rods from a 305 and use in my rebuild, can i do that ? also do the rods and pistons that are in good shape have to be put back in the cyl they came out of. because i did mix a couple of them up. Or should i look at some recond. rods.
Transmission: 4L80E/4L80E
If the 305 rods weigh the same as the 350 rods, no problem.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: changing 2 rods in rebuild
The main reason for numbering rods (which you need to get in the habbit of doing) is so that when the machine shop bores the block, they can fit the right piston to the right hole. Also used to make sure the piston/rod/front of engine orientation is correct.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
