TPS adjustment question
Old Dec 20, 2009 | 10:50 PM
Camaro Man 02's Avatar
Car: 1987 Camaro IROC-Z
Axle/Gears: Idk
I have an 87 camaro with the adjustable tps. can you move the tps up or down to adjust it with out having any meters hooked up to it. cuz i want to do trial and error to try to adjust and i dont have the tools.
Old Dec 20, 2009 | 11:09 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPS adjustment question
Originally Posted by Camaro Man 02
cuz i want to do trial and error to try to adjust .
How are you going to know what voltage it is reading if you don't have a meter connected?
Set the idle voltage too high and it won't even start
Old Dec 21, 2009 | 12:15 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
borrow a meter from somebody. set it to dc volts. .54volts at idle with engine off.. TIP: anything over .64volts sets off check engine light.
Old Dec 21, 2009 | 12:19 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Over 25% TPS(? ) while cranking shuts off the injectors.
Old Dec 21, 2009 | 11:23 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
If you are going to do some basic tuning yourself, you have to buy the right tools for the job. For a minimum, I would say: timing light, volt meter for autos, noid light for injectors, special distributor wrench, fuel pressure gauge, and basic hand tools.
On these TPI cars, you want to be able (for yourself) to do: change out spark plugs, set the timing, set the TPS voltage, measure the fuel pressure, adjust the idle RPM,,,,,
Old Dec 22, 2009 | 02:47 AM
a haynes manual has everything you need to forever keep your car running.
Old Dec 22, 2009 | 10:06 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Good advice. I purchased the factory service manual when I bought my '87,,, I have referred to that manual about a 1,000 times. The Haynes manual is good but not as good as the factory service manual.
Old Dec 22, 2009 | 04:24 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Better than nothing but too generic and does not have the detailed diagnostics for working through engine problems ; especially engine electrical
BurlyChev
Aug 22, 2015 11:42 AM
86IROC112
Aug 21, 2015 07:20 PM
redmaroz
Aug 16, 2015 11:40 PM
perZ
Aug 15, 2015 01:17 PM
bamaboy0323
Aug 15, 2015 07:20 AM
