need fresh new ideas
Old Dec 29, 2009 | 06:28 PM
aablack911's Avatar
Car: 89 Iroc-Z/well in theory
Engine: 5.7 350 TPI
89 5.7 350 been running great except to get it to idle right while driving I would have to tap the gas...works every time. bout a week ago i noticed a loss in power and the oil pressure guage would decrease under acceleration. found what i thought was the problem a joint connecting a vac line from around the fire wall to the egr and that canister up front had broke. replaced helped in the power some but oil pressure now kind of hunting and engine running rich making my eyes water when standing over engine...baby on the way in less then a month and my car has to be running any help greatly appreciated
Old Dec 29, 2009 | 09:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is the SES light coming on?
Old Dec 30, 2009 | 12:47 AM
aablack911's Avatar
Engine: 5.7 350 TPI
Re: need fresh new ideas
actually just now on my way home my ses light came on and when i put it in neutral it would actually idle where its supposed to without having to tap the gas. couple more miles and it died on me started right back up no ses light. ran code when got home 24 which if not mistaken is tps?
Old Dec 30, 2009 | 12:54 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
see what that code is. could be sticking egr valve, corroded pickup coil, fuel pressure (filter) or other maintenance related problem
Old Dec 30, 2009 | 08:24 AM
aablack911's Avatar
Engine: 5.7 350 TPI
Ok fixed my vss issue no ses light. The hose clamp on my intake boot was tightened on with part of the bottom folded in leaving a big hole. But my oil pressure gauge is still hunting. Going up as far as 45 down to like 20 or 15
Old Jan 14, 2010 | 07:31 PM
aablack911's Avatar
Engine: 5.7 350 TPI
needed new oil pressure sensor all better
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jetmeck
Sep 4, 2015 12:29 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
