Can anyone identify these?
Old Jan 7, 2010 | 06:30 PM
Will71's Avatar
Car: 87 Firebird
Engine: 5.0
Transmission: 700 r4
First, a box behind the storage pouch on the passenger's side:
When I removed the lid, this is what's inside:
Second... I found this hose stopped up with a spark plug:
Will
Old Jan 7, 2010 | 07:02 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Can anyone identify these?
Last Photo is a part of AIR injection system. The air diverter valve should be connected to the AIR pump (aka SMOG pump). Smog pump should be on low passenger side.
//RF
Old Jan 7, 2010 | 09:05 PM
Will71's Avatar
Car: 87 Firebird
Engine: 5.0
Thank you for the reply, RFMaster. That would explain why I didn't recognize it. This car was built in California, and I live in Florida. I've never seen a smog emissions *anything* in a car before. Sad, isn't it? So, given that this is plugged, I'm willing to say that this car is *not* green.
Old Jan 7, 2010 | 11:25 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
I think that part in the first photo is the electronic brain for the cruise control.
Old Jan 9, 2010 | 12:25 PM
Pocket's Avatar
Car: 91 Trans Am
Its cruise
The diverter valve splits the air injection into left/right banks (the tube things) and one to the cat. The one to the cat appears to be plugged, likely from exhaust work
Old Jan 9, 2010 | 09:15 PM
Will71's Avatar
Car: 87 Firebird
Engine: 5.0
So... does this car have a catalytic carburetor then? The only reason I ask is because I was told that a catalytic converter was only used with fuel injector systems. I'm not a mechanic, and this is my first project car, so I'm learning as I go.
Old Jan 9, 2010 | 11:00 PM
RFmaster's Avatar
Car: 75 Beast
Just look under your car - if there is a big can looking thing sitting straddling exhaust pipe next to transmission than you (most likely) have a catalytic converter. For sake of completeness - all new cars sold in USA starting 1975 model year were mandated to have catalytic converters. Carb or FI does not matter - all third gens sold in USA came equipped with CATS.
//RF
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
Tweeks25
Sep 17, 2015 08:04 AM
abrilnelson89
Sep 16, 2015 02:19 PM
angel2794
Sep 8, 2015 06:22 PM
