Need some help finding out the number codes on a "350" block
Old Jan 10, 2010 | 12:34 AM
PowerHour84's Avatar
Car: 1984 Z28 Camaro
Engine: 305 -> 383 Stroker
Transmission: T5 -> T56
Axle/Gears: 3.73 Posi
Casting number on the back appears to read 3876010
On the front of the motor it reads MB06800
Can't find any information on it anywhere.. help would be greatly appreciated! Here is a photo of the motor
Attached Thumbnails Need some help finding out the number codes on a "350" block-3m93pd3l15o45pc5saa18392113b5514b1ab6.jpg
Old Jan 10, 2010 | 01:35 AM
Re: Need some help finding out the number codes on a "350" block
I have been doing some research and have found that M probably means built in mexico. I saw online a pontiac block where the second letter in the engine ID was P which = Pontiac, Im not sure if maybe the B in mine stands for buick? Just a guess.. Also saw a GM crate motor with 2800 at the end of the engine ID (which are the last four digits of the product number for the crate engine apparently) , mine is 6800 so my other guess is maybe its a crate motor? I have been searching all over. Please feel free to debunk some of my hunches
Old Jan 10, 2010 | 01:56 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engines installed in vehicles have a 2 or 3 letter code stamped on the pad that tells size /Hp / trans
Old Jan 10, 2010 | 01:57 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It doesn't really matter, it's one of the most common 4" blocks cast and since it's a rebuild, it could be nearly anything.
Old Jan 10, 2010 | 02:22 AM
I am not sure if it was installed in a car now because the suffix contains no letters. There is no partial vin number on the block either, also i could not find that casting number on any website. 010 is a high nickel block correct? the rest of the numbers i cannot seem to match. Its really made me curious. Oh and also it hasn't been rebuilt, but shows minimal wear. Stock 350 bore
Old Jan 10, 2010 | 02:38 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, that's largely a myth, for what little practical difference nickel content makes anyway.
Old Jan 10, 2010 | 02:40 AM
Someone from another forum told me it could be a "target motor" do you know anything about those? Im pretty lost when it comes to this lol :P
Old Jan 10, 2010 | 05:20 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Someone from another forum told me it could be a "target motor" P
Was a in house name for GM crate replacement engines made in Mexico way back,
http://www.novas.net/forums/showpost...7&postcount=10
Old Jan 10, 2010 | 06:10 AM
Thanks bro
evilstuie
Feb 28, 2016 03:33 PM
blackd-out z28
Aug 15, 2015 08:18 PM
armybyrd
Aug 10, 2015 09:23 PM
antares57
Aug 6, 2015 07:47 AM
