Bahgging down WHen i Hit the gas!!
Old Jan 11, 2010 | 05:00 PM
Daapunk's Avatar
Car: 88" Trans am
Engine: 350 bored. 383 Stroker Kit
Transmission: Power Glide
Axle/Gears: 4:10
hey guys, my car is once again not fireing as hard or something and bahgging down when i hit the gas is kinda bahhgs then goes and really doesnt take off like it was. i know its not my catalic converters there already cut out. i have 305 tpi. ive never replaced any sensors or anything u think maybe some of them or what could it be any ideas? when i first crank it up from sitting over night it stays revved up to like 1200 rpms and when i put it in drive it will just take off on its own and even change gears!!!! and when i have to stop befor its warmed up i have to apply the brakes harder because my car is still trying to go and all i do is let off brake and it goes again till about a mile or so until its warmed up hahah. what could this be...?? stoped fuel filter? my plugs and wires are not too old i replaced them pretty recently. when i cut my car off i can hear my fuel pump whinning and whilisting watever u call it when i cut car off hahah would that be causing my bahging down problems and or high revs and car tries to go on its own. please help guys!!!
Old Jan 11, 2010 | 07:32 PM
Daapunk's Avatar
Car: 88" Trans am
Axle/Gears: 4:10
Re: Bahgging down WHen i Hit the gas!!
no help or ideas? my car is hard to stop on warm-up im sure its more wear on my brake pads plus my car doesnt fire and hit and hard as it use to.
Old Jan 11, 2010 | 08:32 PM
alexsholly's Avatar
Car: 91 rs
Engine: 305 tbi
maybe spark plugs i had a carbed z28 do tht changed the plugs and it helped on my car might not be the plugs tho.
Old Jan 12, 2010 | 07:55 PM
Daapunk's Avatar
Car: 88" Trans am
Axle/Gears: 4:10
i know im gonna try that maybe again i guess and see start out cheap. kuz today i was using my heater and at the red light my A/c compressor or something would kick in raise rpms and try to pull me forward... ugh... but does have weak acceleration seems like its louder and making more air intake but just isnt going.... i dunno
Old Jan 14, 2010 | 09:07 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
you need a multimeter and check the values of the voltage on the throttle positioning sensor
Old Jan 14, 2010 | 12:10 PM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
I've got a 305 tpi that does the same thing. It idles really high (1200-1500 rpm) until the engine warms up. Mine is a manual so I don't have issues holding it back at a stop but while it's idling high I don't have to give it any gas to take off. I just ease the clutch out and it tries to twist the tires off. Once it is warmed up it idles just fine around 700-800rpm. I have replaced plugs, wires, and coil, set tps voltage, cleaned iac valve and reset idle speed, and thoroughly cleaned the throttle body and blades. Nothing has really affected the high idle issue. Mine does not bog down on accelleration though so that might be a seperate problem. I'm going to keep working at it and I'll keep you posted if I figure anything out. Does anyone know what other componets control idle speed on the tpi system?
Old Jan 15, 2010 | 09:34 AM
jamon8's Avatar
Engine: 350 tpi
you could have a vaccum leak
you need to test the tps and make sure the values from idle to wot are constant all the way through the moving of the throttle
Old Jan 16, 2010 | 03:08 AM
Goany's Avatar
i say about a 75% chance its the mass airflow sensor(MAS) get it checked or or have a shop scan your car that will help a lot cause it can watch you fuel mixtures and will show signs of a bad MASm
Old Jan 16, 2010 | 07:02 AM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
Could be a bad MAF or MAP sensor if your car is SD system. Also what the other guy said, check your TPS voltage. If its out of spec, it can/will cause alot of these problems you have mentioned. Also clean and check your IAC.
Old Jan 16, 2010 | 06:56 PM
64elko's Avatar
Car: 64 elcamino
hello
i am haveing same thing going on in my 305 tpi,,,now i unhooked the vacum lines to the canster and the idol came down to 500-800... so i will change the map,can you tell me the best way to clean the vac and reset it...
64 elko
Old Jan 17, 2010 | 08:52 AM
jamon8's Avatar
Engine: 350 tpi
wait
what?
clean the vac
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Rally Smith
Sep 14, 2015 06:59 PM
Glowsock
Sep 11, 2015 11:09 PM
87camaro87
Sep 9, 2015 10:29 PM
