New motor sitting in garage
Old Jan 12, 2010 | 01:14 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I have a new engine for my LT1 build sitting in my garage wrapped in a plastic bag. How long would it be ok for the engine to sit around for before anything is done with it? I am worried about rust/etc. forming in the insides... it is a fully assembled long block with heads, valvetrain, intake installed and sealed. I taped the exhaust ports and the intake holes. It is also filled with 6 qts oil.
I need a few more months before i can start it up so should I be worried or what should I do for protective measures? The garage is heated and has never gone below 58 degrees.
Old Jan 12, 2010 | 01:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: New motor sitting in garage
As long as it was properly lubed when it was built and you get it installed within the next 50 years, you should be ok.
Old Jan 12, 2010 | 10:28 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I bought a wrecked 93 years ago, stored the engine. I got some marine fogging oil and sprayed it in the cylinders. Stuff is made for boat storage. Sure hoping it will. In your heated garage you should have no problems.
1992rs/ss
Jan 31, 2025 05:10 PM
Street Lethal
Apr 30, 2019 12:14 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
