blew a head gasket
Old Jan 16, 2010 | 03:50 AM
kinglui408's Avatar
Car: iroc-z
Engine: 305 tpi
Transmission: auto
Axle/Gears: lol
blew a head gasket
ok. so i got a 305 tpi. driver side head gasket is toast. i gota make my baby run again. now. here is the question. should i take the heads and see if they are salvagable. build em up and throw a cam. or should i go with vortec heads. now. im new to the vortec head swap scene. i hear alot and read alot of info. of course both routes will grant me to get a better cam. lol. but this is more for suggestions. build up the current set up, or get vortec heads and intake.
Old Jan 16, 2010 | 11:37 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: blew a head gasket
how much money do you have to spend?
Old Jan 16, 2010 | 12:38 PM
rockstar08's Avatar
Car: IROC-Z
Vortec Style heads have a different intake/base plate. It gets to be expensive with only little HP gain in my opinion. If your heads are trash, ( they're pretty tough ) i'd go for CNC milled ones, a nice mild cam swap to match, and a tuning session on the dyno.. its cheaper and you'll feel like you've got something for your pain..
Old Jan 17, 2010 | 03:24 AM
kinglui408's Avatar
Car: iroc-z
Engine: 305 tpi
Transmission: auto
Axle/Gears: lol
i got about 1g to do this
Old Jan 17, 2010 | 09:13 AM
jamon8's Avatar
Engine: 350 tpi
those tpi heads are not horrible unless you are making big power
I would see if they are salvagable and put some springs on them
do a cam swap
what kind of exaust are you working with
I would do exaust before heads
worry about heads when you switch to a 350
right now what you want to do is get ready for the 350 by replacing all the external motor stuff over
make that 305 last as long as possible
do a timing chain and an oil pump
port out the plenem
subframe connectors!!!!
Old Jan 19, 2010 | 02:02 PM
kinglui408's Avatar
Car: iroc-z
Engine: 305 tpi
Transmission: auto
Axle/Gears: lol
do a cam swap
port out the plenem
i have some headman headers that i was gonna install on a sunny day. so, what kinda springs should i get for the heads, and what cam do you recommend
Old Jan 20, 2010 | 08:13 AM
jamon8's Avatar
Engine: 350 tpi
something around a 268 dur
480 lift
get the springs to match the cam in the specs of the cam
3rd gen money
Sep 8, 2015 11:40 PM
509 camaro fan
Sep 6, 2015 10:43 AM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
