Starter and Battery Question
Old Jan 16, 2010 | 06:36 AM
slow305rs's Avatar
I've swapped out my starter to a mini CVR hi-torq unit. Also relocated the battery to the trunk (Optima battery and BMR bracket).
Just wondering what gauge wiring I should use to run from the starter to the battery.
I was thinking of using 10 ga wire.
What do you suggest? Do I need to go this big with the wire?
Old Jan 16, 2010 | 11:36 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Starter and Battery Question
0 gauge
Old Jan 16, 2010 | 03:11 PM
slow305rs's Avatar
Why such a big gauge wire for a starter?
Old Jan 16, 2010 | 03:21 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Starters pull alot of current.
Old Jan 17, 2010 | 09:05 AM
jamon8's Avatar
Engine: 350 tpi
yep
Old Jan 17, 2010 | 01:29 PM
50bmgshooter's Avatar
if you run a 10 wire for the starter you better have a fire extinguisher handy
you can run a 2 gauge wire if you are woried about weight if not use a 0 gauge wire
Old Jan 17, 2010 | 01:31 PM
slow305rs's Avatar
0 ga it is...thanks guys.
Old Jan 17, 2010 | 01:50 PM
I use welding cable
holds up to heat, and weather plus its very flexible
and can be bought at any welding supply and the usually have the ends youll need
also I solder the ends on
the way I do it is lock the end in a vise heat it with a small torch and feed in the solder when you have filled the end up about 3/4 of the way remove the heat and stick the wire in and hold untill it cools then shrink wrap the end
Old Jan 19, 2010 | 01:12 AM
84Z28406's Avatar
Originally Posted by 50bmgshooter
I use welding cable
I understand why you would use welding cable, but why would flexibility matter in an application like this?
Old Jan 19, 2010 | 08:44 AM
jamon8's Avatar
Engine: 350 tpi
I use it and it works well
Old Jan 19, 2010 | 09:00 AM
due to temp changes that the car goes threw and the flexibility of all cars the cable will always be moving a little bit each time the car is driven.
Old Jan 19, 2010 | 10:48 PM
84Z28406's Avatar
Ok, fair enough.
Frozer!!!
Jan 19, 2024 04:55 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
