350 heads on a 305 - What head gasket?
Old Jan 19, 2010 | 07:59 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Would you want to run a 305 size bore gaskets or a 350 size bore gaskets if your running a set of 350 heads on a 305
Old Jan 19, 2010 | 08:17 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: 350 heads on a 305 - What head gasket?
either one 350 may be cheeper,may kill compression going with 350 heads.
Old Jan 19, 2010 | 08:25 PM
FueledSoul's Avatar
heads are 54cc
Old Jan 19, 2010 | 09:15 PM
FueledSoul's Avatar
What about the gaskets?
Old Jan 19, 2010 | 09:36 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Don't think it makes any difference;
From Jegs:
Mr. Gasket #720-6100G
# MLS Premium Overhaul Gasket SetSB-Chevy 283-350 1958-85
Old Jan 19, 2010 | 11:46 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
From Jegs:
No head gaskets are made for individual bores not just small block or big block. I'd run the 305 gaskets.
Old Jan 20, 2010 | 12:13 AM
Guest
Guest
Posts: n/a
What heads are they? You should try to use the 305 gasket if possible but sometimes the chambers on the 350 heads are larger than the bore (and gasket bore) and can cause sealing issues.
Old Jan 20, 2010 | 10:17 AM
FueledSoul's Avatar
There converted Stock gen2 LT1 heads
Old Jan 20, 2010 | 10:02 PM
FueledSoul's Avatar
hmmmm, well anyone? the heads have 1.94s and 1.5s id guess a 305 gasket would work but id like to know for sure
Old Jan 20, 2010 | 10:55 PM
Guest
Guest
Posts: n/a
Pretty sure that chamber is too large to cover the 305's gasket hole.
Old Jan 21, 2010 | 10:00 AM
Engine: 355
Got any pics i would like to see them?
Old Jan 23, 2010 | 05:41 PM
FueledSoul's Avatar
once i get them put together im waiting on my porting kit, im going do a mild port and polish job them then have them decked. thats why i need the gasket to get it ready to drill the new holes for the coolant after decking
Old Jan 23, 2010 | 11:14 PM
jfitz513's Avatar
if u run aluinium heads it wont kill that much power tho plus lighter to positives
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
355tpipickup
Aug 25, 2015 12:54 AM
NinjaNife
Aug 23, 2015 11:49 AM
