code 44 most likely cause?
Old Jan 20, 2010 | 04:18 PM
thetaman85's Avatar
Car: 85 Firebird Trans Am
Engine: Rebuilt 305 Carb
Transmission: Built 700R4
Axle/Gears: The unfortunate Open Diff, 3.23
my 85 t/a 305 tpi has been putting out a code 44 intermittently my haynes manual says it could be bad fuel injector(s), low fuel pressure, defective maf sensor, defective o2 sensor or defective ecm (which i just replaced), i have pretty much ruled out a vacuum leak as i cant hear or see one which of these is the most likely cause of my problem? the idle fluctuates and sometimes at a stop in gear it will choke the engine
Old Jan 20, 2010 | 08:01 PM
wesley_pontiac's Avatar
Car: 86 Pontiac Firebird
Engine: 2.8 liter V6
Axle/Gears: 10 Bolt 2:73
Re: code 44 most likely cause?
have you tried these yet???
44 ECM idle switch circuit open
44Oxygen sensor or circuit - lean exhaust
Old Jan 20, 2010 | 08:35 PM
thetaman85's Avatar
I have only eliminated Electrical connections vacuum leaks and ECM as possibilities I simply wanted to see if anybody had an idea of what is most likely before I spend alot of money throwing parts at it I only make minimum wage and every dollar counts all help is appreciated
thanks
Old Jan 21, 2010 | 02:33 PM
i understand exactly wat u mean bout making min wage and evry dollar counts. and no problem.
Old Jan 21, 2010 | 07:27 PM
thetaman85's Avatar
I have changed the fuel filter and tested the injectors also. I am going to change the oxygen sensor b/c I got it when I changed the alt. With the core charge the sensor was free if not that then maybe egr valve is next
thanks for all your help
Old Jan 21, 2010 | 08:24 PM
sounds lik a plan and as long as u hav 1,thats wat matters. and no problem at all.
Old Mar 26, 2010 | 05:42 PM
Jonboy2312's Avatar
Car: 1986 SC based 82-84 Z28 replica
Engine: 2.8 V6 MPFI
Transmission: TH-700R4
Did the new oxygen sensor help?
Old Mar 26, 2010 | 05:46 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
you need to get a hold of a gm diagnostic diagram... or something like mitchell diagnostics... or you can google the various steps to diagnose each of those possibilities...
Old Apr 30, 2010 | 11:26 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
I just want to add when the alternator is bad and the battery drains while driving, a code 44 will be displayed because of lack of power to spark and fuel pressure. A charged battery and computer reset will fix this problem is most cases. happened last night to me
Old May 11, 2010 | 02:20 PM
welchk85's Avatar
Car: 1990 camaro rs 3.1 v6
Engine: 3.1 v6
i have a 90 camaro 3.1 v6 and im getting the code 44 as well but i put in a new alternator and realized the battery is like dead im replacing it on thursday but do you think the battery would be the problem because i just replaced pretty much every sensor other than the o2
Old May 20, 2010 | 09:37 PM
hawkdriver's Avatar
Car: 87 GTA / G8 GT
Engine: 5.7L / 6.0L
Transmission: auto's :(
What ended up being the problem?
Old May 21, 2010 | 08:59 PM
thetaman85's Avatar
sorry for the late response, been busy but it was the o2 sensor fixed it good. havent had a spectacular experience with that motor so im gunna swap it out for my brothers rebuilt and built up 305
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
