what is the best to use to fix a timing cover seal oil leak?
Old Jan 20, 2010 | 06:56 PM
palmerracing83's Avatar
Car: 1983 z28 camaro
Engine: h.o. 305
Axle/Gears: posi
1983 z28, 305, the timing cover is leaking down by the rubber seal, what is the best way to fix it without taking the timing cover off?
Old Jan 20, 2010 | 08:32 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: what is the best to use to fix a timing cover seal oil leak?
You could pull the balancer and pop the seal out with a screwdriver. But it will be easier to pull the balancer and the timing cover and knock the seal out from backside.
Old Jan 20, 2010 | 09:33 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If an oil additive will stop your leak, this one will:
http://www.goldeagle.com/brands/no_leak/default.aspx
I've used the engine oil treatment in two engines and it slowed or stopped the leaks. I'm not one to do the additive thing; I just tried it to buy some time before I can repair the leak properly.
Old Jan 20, 2010 | 11:52 PM
Engine: h.o. 305
Axle/Gears: posi
no no no its not the oil seal that goes in the timing cover over the crank shaft behind the balancer its the very bottom rubber seal that goes between the timing cover and the oil pan.
Old Jan 21, 2010 | 12:05 AM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
new pan gasket.... or if its temporary remove the front 4 or so pan bolts on each side and loosen the back ones, enough to drop that pan down a little bit, load it up with RTV and sinch it back up.
Old Jan 21, 2010 | 09:07 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
You can leave the timing cover on and remove the pan. Replacing that seal doesn't require removing the timing cover.
Old Jan 21, 2010 | 10:45 PM
Engine: h.o. 305
Axle/Gears: posi
ok cool thanks guys im tryin that in the mornin, didnt think of droppin the pan lol............ thanks!!!
Old Jan 21, 2010 | 11:21 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Your going to have to raise your engine a little so you can get enough clearance to get the pan out. A few blocks of wood and hydraulic jack under the cranks shaft should do it, that's how I replaced my oil pan gasket and oil pump. Just make sure you notch the top block of wood so it doesn't roll off the crank.
Alex
Old Jan 21, 2010 | 11:26 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Alex
Even with a forged crank I dont think I'd want to jack it up by the crank snout.
Old Jan 22, 2010 | 08:31 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
It won't hurt the crank.
Old Jan 22, 2010 | 08:41 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
why not take the water pump off, timing cover off and put a chain in it while you are there
if you drop the pan then why not change the oil pump
thats what I do with pretty much every high mileage engine and right now I have a 226k cavalier that runs like a top
Old Aug 5, 2012 | 01:56 PM
Brandon Taylor's Avatar
how to fix a leak at the bottom of my timing cover.
I have a 1978 1500 2wd gmc with a 305. Its leaking down at the bottom of the timing cover but i just replaced all the seals on the timing cover and its still leaking!! I dont know what esle to do. Any Advice?? please help
Old Aug 5, 2012 | 06:46 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: how to fix a leak at the bottom of my timing cover.
That is a common oil leak on sbc. check the condition of your oil pan gasket when you loosen the pan, if it is in good shape , I would use some rtv on the front seal and tighten back up. Might as well replace timing cover seal and timing cover while your at it for peace of mind.
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
Exxon Limited
Aug 9, 2015 08:13 PM
drathaar907
Aug 6, 2015 04:20 PM
