White smoke
Old Jan 20, 2010 | 09:30 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
White smoke
I just bought another thirdgen, this one is a 1982 camaro 305 HO 4brl. I got it started and let it ran for 15 mins that day, then next 3 days came by and I was hoping the white smoke was just oil or water in engine because it was sittign for 6 years. I havn't put any gas in the car guessing the gas is still 5 years old. It will puff white smoke out then disappear fast when at idle but when you give it gas maybe at 3,000 rpm it will make a cloud of white smoke. I was guessing head gasket or cracked head. I oil was complete black, so I change the oil it looked 100% pure oil, after the oil change it still made the white smoke and there isn't any green in the oil. I then let the car sit over night and open the radiator cap, and it still had alot of pressure, so would what do you think it is?
Old Jan 20, 2010 | 09:34 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Re: White smoke
It sounds like your motor is burning oil. Pull some plugs and take a look.
Old Jan 20, 2010 | 10:32 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Re: White smoke
Yeah, that what I think the guy said when he he drove it from Oregon to Washington it burned one quart of oil, but he just said it was because it was driven in such a long time. If its the ring on the piston anyone know how much that cost? I also have to fix the reverse in 4 speed manual transmission.
Old Jan 20, 2010 | 10:51 PM
Goany's Avatar
Re: White smoke
um check your oil level run that gas through and put some fresh in and then change the fuel filters buddy just to prevent future problems xD as for rings it your gunna take it apart to replace rings first get your valve job and get new valve seals and stuff and see if the smoking stops before you jump into the rings. If you dont mind me asking though how many miles are on the motor/car?
Old Jan 20, 2010 | 10:59 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Re: White smoke
Speedometer says 54K, the lady who owned in Oregon had receipts from ties changes and oil chanhes that said XXX,XXX miles, i also check the car fax and nothing, so I'm guessing 50k? I'll change them out and see, maybe I'll take a video of the whole car so people can see.
Old Jan 21, 2010 | 01:23 AM
Goany's Avatar
Re: White smoke
that would be awsome then ill show you mine xD
Old Jan 21, 2010 | 11:43 AM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Re: White smoke
White smoke is related to water/coolant.
Blue = oil
Black = too rich/not enough spark.
With that said, keep track of your coolant level. If it sat for 6 years, I would say it could be an intake gasket or possibly a blown head gasket. Start the car and remove the radiator cap. Look inside the radiator and see if the coolant is bubbling more than it would normally. Let us know what you find.
Why did it sit for 6 years? Blown head gasket? Some other problem?
You might want to try and re-torque the head bolts and intake manifold bolts and see if it helps. Worth a try.
Old Jan 21, 2010 | 11:56 AM
86toy's Avatar
Car: 86 transam,700r4,4 wheel disc,possi
Engine: 305 tpi/stock for now
Axle/Gears: not sure
Re: White smoke
white smoke= blown head gasket or intake leak sucking water or cracked head or block, or just water in oil from sitting, do a leak down test and compression test to see where its leaking.
Old Jan 21, 2010 | 04:29 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: White smoke
Blue = oil
Jake
Old Jan 21, 2010 | 09:12 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Re: White smoke
okay, I'll do that, what the torque order?
Old Jan 22, 2010 | 07:38 AM
JakeJr's Avatar
Axle/Gears: 3.07
Re: White smoke
Even after all the heads I've torqued down over the years I've never tried to memorize the sequence. My thinking is it's too easy to make a mistake. So each time I tackle that chore I sit the manual in the lifter valley with the page having the sequence open.
That's the best advice I can give you on that. If you don't have a manual, you should buy one. It'll come in handy over and over.
Jake
Old Jan 22, 2010 | 12:13 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Re: White smoke
The oil is once black again, there is no milky look in it at all, the radiator is completely full and still had alot of pressure after 3 days. The exhaust smells like fuel, there is wet spots on the ground from giving it gas. I was trying to tune the carb and it look like the smoke was going away. I'm guessing its fuel mixture. What do u guys think? I can't tell if the oil level drop any, the smoke was like a dark white or blue, I guess.
Old Jan 22, 2010 | 12:20 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: White smoke
I still would suspect valve guide seals, common to go bad, especially after sitting....sometimes hard to tell if white or blue smoke. coolant leak internal would not always get into the oil, and usually will drain you radiator. So if its still at same level it might be an oil problem.
Old Jan 22, 2010 | 02:29 PM
Goany's Avatar
Re: White smoke
about the vavles hell it would be worth it cause there gunna go bad eventually yah know?
Old Jan 22, 2010 | 02:30 PM
Engine: L98 494hp
Re: White smoke
yeah, they're crappy new. replace them with umbrella style seals...not too big of a job and coudn't hurt
Old Jan 22, 2010 | 09:20 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Re: White smoke
If it the piston rings, head gasket, or w/e it is. I was just going to get it fixed but found out it would cost around 1000 or so....so a full rebuild kit about 350 then some tools be about the same 1000, I'll just rebuild the engine in my little shed outside. I also found a good link for a dvd "boxwrench dvd" I'll use that and a little knowledge and get her done.
Here the link if anyone esle wants to download total of 6.3 GB or something 210 minute long dvd.
http://digul.net/content/basic-engin...p-instructions
Old Mar 21, 2010 | 09:55 PM
z28maro91's Avatar
Car: '83 z28/'85 iroc
Engine: L69/LB9
Transmission: 700r4/700r4-b&m shift kit
Re: White smoke
Im thinkin i have the same problem with my 83 z. I only paid 300 for my car though, haha its been sitting in a garage for 15 years. Well i finally got it to start the other day and theres grey/bluish smoke coming out of what appears to be the exhaust manifolds. I just put in valve cover gaskets so it can be coming outta those. I cant really figure out whats wrong
Old Mar 21, 2010 | 10:05 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Re: White smoke
What have you done after it sat for 6 years?
Did you clean the fuel tank and system and so on?
Did you give it a tune-up?
What have you done?
Old Mar 21, 2010 | 10:26 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: White smoke
valve stem seals?
Old Mar 22, 2010 | 09:25 PM
tater's Avatar
Transmission: TH350
Re: White smoke
Pull your plugs and post the result of what they looked like. I have had one plug become so fouled that it would not fire. Thus, sending raw fuel down the exhaust pipe creating a fuel smelling white smoke.
Read those plugs......all of them. Let us know.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
