Losing Spark.
Old Jan 23, 2010 | 02:57 PM
Joeman4jc's Avatar
Car: 92 Camaro Rs
Losing Spark.
Howdy,
Wondering if anyone can shed some light on my situation. I have a 92 Camaro RS throttle body, and i'm having some trouble figureing out why i'm losing spark. The car will start after it's been sitting a little while, but after it runs for about 5-7 minutes the spark coming from the coil starts to become inconsistant and eventually just dies out. I've put a new coil on, didn't change. I went to Advanced and O'Rileys to have the Ignition Controll Module tested and it tested ok every time (Advanced tested it twice, and O'rileys tested it 3 times.) I'm convinced it's not a fuel issue since i can watch the fuel be dispenced fine through the throttle body. I can also hear the fuel pump kick in. Anyone had a problem like this that they can fill me in on what the deal is?
Thanks.
Old Jan 23, 2010 | 08:45 PM
Joeman4jc's Avatar
Car: 92 Camaro Rs
Re: Losing Spark.
Turns out it actually was the Ignition Controll Module. Went to Auto Zone and had them test the old one again. He tested it 7 times, right after another, and it tested fine. Got home and put a new one on just for the sake of being safe and bam. Car started, and ran like a dream.
Just a tiny bit of advice anyways.
Thanks.
Old Jan 23, 2010 | 08:58 PM
carkook's Avatar
Re: Losing Spark.
I dont see how they bench tested it. The only way to test an ignition control module is too have it all hooked up, test the signal it recieves and verify that it is correct, then test if it is pulsing the primare side of the coil.
MM2Robinson
Oct 1, 2017 09:16 AM
PurelyPMD
May 5, 2016 04:57 PM
Giocio
Oct 1, 2015 12:20 PM
Stryker412
Sep 20, 2015 06:59 PM
bryan623
Sep 19, 2015 10:13 AM
