Can you use a factory roller cam in a non roller block w/ retro fit lifters?
Old Jan 25, 2010 | 02:24 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
My question is this. Can I use a Hot cam in a non roller block with retro fit roller lifters?
I don't think I can because don't know for sure.
Thanks.
Jason
Old Jan 25, 2010 | 02:54 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Can you use a factory roller cam in a non roller block w/ retro fit lifters?
Yes but you need a cam button to hold the cam in and a roller cam timing gear because the cam bolt pattern is smaller on the roller cams
Check this out
http://www.lingenfelter.com/mm5/merc...egory_Code=C30
This 3rd Gen member installed studs in the front of his block to use the stock style cam retainer
https://www.thirdgen.org/forums/post...0-post104.html
https://www.thirdgen.org/forums/post...8-post107.html
Some have converted their blocks to use the late model hardware
https://www.thirdgen.org/forums/tech...ck-accept.html
Old Jan 25, 2010 | 09:20 AM
LilJayV10's Avatar
Engine: 406 Roller
Sweet. Thank you for the reply.
Old Jan 25, 2010 | 10:12 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Check into this a little deeper. There's something different about the dowel pin lengths and maybe some other issues.
I just don't want you to run into any surprises.
Jake
Old Jan 26, 2010 | 12:29 PM
stoning_volcom's Avatar
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
Yea the dowel is longer but you should be able to take it to a grinder and make it shorter other then that and the timing chain and cam button you should be good to go, here is something for yea i no that summit racing sells a cloyes timing chain cover that comes with a built in cam button adjustable so that might be something you wanna look into
Old Jan 26, 2010 | 07:45 PM
C305's Avatar
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
How do you know if your engine is a roller or not.
Old Jan 26, 2010 | 07:51 PM
Damon's Avatar
You also need a factory cam retaining plate that you cut the "ears" off of and continue to use as a spacer. You also have to use a factory-style roller cam timing chain (an old flat tappet chain set won't bolt to a factory roller cam). PLUS the afore-mentioned aftermarket roller lifters and cam button.
Old Jan 27, 2010 | 01:23 AM
EvilCartman's Avatar
Car: '82 Z28
Ahh yes... I went through this last year. My 90 block didn't have any of the threaded holes for factory roller stuff, just the blank bosses. Used a set of retrofit roller lifters, LT1 camshaft plus the LT1's camshaft retaining plate and picked up a timing chain set for a 92 Camaro with factory roller setup. Drilled and tapped the block, very carefully, for the retaining plate and assembled as normal. Didn't need to use a cam button doing it that way.
Old Jan 27, 2010 | 01:47 AM
LilJayV10's Avatar
Engine: 406 Roller
I appreciate the reponses. The only reason I ask is I am throwing together a budget 383 w/ parts I have laying around w/ vortec heads. I have a LT4 hotcam and a retro fit roller 288. I thought the 288 would be to big but after reading a 50 page thread on nasty28.com I think I am going to try it.
It is interesting to see what people are doing to get around this issue though.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
RyanJB
Sep 14, 2015 03:39 PM
