Goodwrench 350 Good/bad?
Old Jan 27, 2010 | 10:21 PM
CrAlt's Avatar
Car: 83 TA
Engine: goodwrench 350
Hey all..
Ive done some searching and found posts going WAY back..
Is anyone currently running the "stock" crate 350? (10067353)
My 83 T/A has a stock 305 with 140K.. getting tired..
Does anyone have this engine in their car? Are you happy with it?
The price isnt bad for a nice clean NEW motor that I could have in my garage in 2-3 days..
Old Jan 27, 2010 | 11:09 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Goodwrench 350 Good/bad?
Good engine for stock replacement. How much they going for now? You may be able to buy or build a better engine for the same money.
Old Jan 28, 2010 | 07:27 AM
CrAlt's Avatar
Car: 83 TA
This is just a cruiser so im not looking for big HP. Just a hassle free swap.
Jegs has them for about 1600 SHIPPED
Old Jan 28, 2010 | 12:32 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
You couldn't build anything better for that money.
Old Jan 28, 2010 | 02:05 PM
Damon's Avatar
I've installed several of them over the years in place of tired/worn out stock 305s. Great motor for the money. It'll feel like you strapped a second engine under the hood compared to a stock 305 (45 more cubes make a world of difference in torque). And it runs fine on garbage gas.
If your Camaro has the smaller/low output 2-1/4" cat/intermediate pipe/muffler you should consider upgrading to something bigger/better. That exhaust was restrictive even on a little 305. On a 350 it'll choke the life out of it as RPMs rise. On the cheap, yes, it will bolt up just fine and run OK, but it's not for any kind of performance intentions.
The low output LG4 305 engines came stock with that pea-shooter exhaust. The high output L69 305 came with bigger everything (manifolds, y-pipe, cat, intermediate pipe, muffler), and is acceptable for use with a mild 350 (but even that is just barely acceptable). Shortie headers & y-pipe with a 3" exhaust from there back would be more than enough and still leave you headroom for even more Horsepower/upgrades later.
Old Jan 28, 2010 | 02:28 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Im on my second. I had bought a new goodwrench shortblock for $800 for a truck I used to have, but sold the truck. The shortblock ended up in the camaro instead. With the cam and heads its probably somewhere in teh neighborhood of 375 HP at the crank.
My experiences with my first one where generally good. I took it out when the bearings wore out. The quality is ok, but I did find some minor machining defects here and there. Not enough to compromise the engine, though.
Should be interesting to see how long the second one lasts in the current setup. I shift it at about 6k to get teh best performance out of it, and abuse it liberally. I figure if it blows, I can always finish rebuilding teh first one.
TX-SleeperC5
Feb 24, 2016 01:34 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
z28guy134
Sep 1, 2015 11:50 PM
