help! my son sprayed too much starter fluid
Old Feb 3, 2010 | 09:20 PM
ladymav's Avatar
Car: 91 Camaro RS
I was trying to start my 91 RS and my son decided that while I was cranking and he thought it was going to start, to continuously spray the starter fluid. It started a fire, which continued to burn probably 5 mins. Now the car won't even turn over. What damage has been done??
Old Feb 3, 2010 | 09:26 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
Re: help! my son sprayed too much starter fluid
pull th spark plugs, crank the engine for 5 seconds and put them back in, should be fine unless and wires or anything burned up!
Old Feb 3, 2010 | 09:29 PM
ladymav's Avatar
Car: 91 Camaro RS
Will try that in the morning. Thanks for the reply. I hope nothing burned, as I would have no idea where to go from there!
Old Feb 3, 2010 | 09:37 PM
ls six's Avatar
If it's a V6 it'll have a MAF sensor. It can easily be destroyed by a back fire or burning fuel/starting fluid.
Old Feb 3, 2010 | 09:38 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
the cylinders are probably full of fluid locking the motor up> seen it happen a ton!
Old Feb 3, 2010 | 09:41 PM
ladymav's Avatar
Car: 91 Camaro RS
Is six... its a V8 (305)
Iroc ZZ ... if they are full of fluid, will pulling the plugs as you said earlier solve that??
Old Feb 3, 2010 | 09:46 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
yeah, it should allow you to turn the motor over and pump it all out
Old Feb 3, 2010 | 09:52 PM
ladymav's Avatar
Car: 91 Camaro RS
Thanks a lot, I have really been stressing about this. (still am a little)
budowski
Carburetors
Oct 2, 2015 10:16 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
camarohelp
Sep 22, 2015 03:19 PM
sahlomonic
Sep 20, 2015 07:15 PM
Formula_88AE
Sep 3, 2015 01:47 PM
