just got lucky and unlucky at the same time
Old Feb 3, 2010 | 09:29 PM
89fireeagle's Avatar
Car: 89 firebird 83 t/a
Engine: 305 tbi
well i just bout this 82 t/a for a 100 bucks there no rust on any of the body idk what kind of motor is in it but i also have a 89 firebird and i want to put the 4 bbrl and intake and heads from the t/a they will all fit i no that so far but how do i do that if the 89 firedbired it a tbi i would like you guys to give me some tips on how to do this and i want no ac just heat and i dont want the smog is this possible. and if i am in the rong forum inform me plz
Old Feb 3, 2010 | 10:41 PM
Brother Al's Avatar
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
Re: just got lucky and unlucky at the same time
If the 1982 T/A has an electric Q-jet carb, (E4ME Q-jet), it is the LG4 305. Those parts will not swap over, as the '87-'92 SBC used a different style of heads & intake manifold that DO NOT interchange with the traditional pre '87 SBC design. The Q-jet would also be useless because the TBI's distributor & computer system (ECM & PROM) would not be able to read any of the data it needs to operate. It would be like trying to plug an Atari game into a Nintendo...
That said, $100 is a steal for an '82 T/A that is all/mostly original and complete, regardless if it runs or not. The car is worth far more than you realize and chopping it up would be a tragic mistake. I recommend selling the T/A on here and using that money to buy what you need to modify your '89 Firebird.
Old Feb 3, 2010 | 11:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The intake interchanges between the different heads just fine when you modify the center bolt hole on the intake for the different bolt angle. Either way it's a moot point when you swap the heads along with the intake.
Old Feb 4, 2010 | 06:25 PM
Brother Al's Avatar
True, I should have clarified a bit more, but the basic mannerism of the post and the belief that the parts easily interchange made it easier to reply as I did. That route would offer very little value and the carb & dizzy would be useless. Selling the early Bird would give him capital to purchase a proper intake, HEI, and carb.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
