Wont kick over
Old Feb 4, 2010 | 01:57 PM
91Firebird98844's Avatar
Wont kick over
I will be aquiring a 1991 Firebird with the 3.1 V6 and it has one issue that I have been trying to troubleshoot.
It is having issues kicking over. Its getting spark and fuel. It was given a fresh tune-up with new cap, rotor, wires and plugs and before the tune up, it worked great. Ever since the work was done, it hasnt kicked over at all. When you turn the key, you can hear the fuel pump priming the system. Then when you turn the key, it will keep cranking but wont start.
Any ideas would be of great help. Thank you.
Btw, I am from Washington State (Okanogan County to be specific) if anyone wants to know.
Old Feb 4, 2010 | 02:30 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Wont kick over
what is your fuel pressure?
Old Feb 4, 2010 | 02:32 PM
Re: Wont kick over
also make sure it has the right spark plugs. if the reach is too short it wont start.
Old Feb 4, 2010 | 02:36 PM
Re: Wont kick over
Normal I presume. When we took a plug out to check them, they did have gas on them. How would one measure this?
They are the right plugs. But just in case, I might get new ones all the way around and not the "AC Delco" brand. What are some good recommendations for spark plugs? Nkg? Autolite? Bosch?
Old Feb 4, 2010 | 02:41 PM
Re: Wont kick over
the spark plug threads should be .708".
Old Feb 4, 2010 | 02:49 PM
Re: Wont kick over
What about the gap?
Old Feb 4, 2010 | 03:11 PM
Re: Wont kick over
gap isnt that important but should be .040-.060
Old Feb 4, 2010 | 03:45 PM
Re: Wont kick over
Okay.
Old Feb 4, 2010 | 06:36 PM
Steve86TA's Avatar
Car: To many to list
Re: Wont kick over
Go back through all the tune-up parts that were replaced.Make sure everything is secured and the firing order is correct.
Old Feb 4, 2010 | 07:10 PM
Re: Wont kick over
I am next time I am home. I am a long haul truck driver so I dont get home as often as I should. But anyways, next time I am back home, I am gonna get all new wires, plugs, rotor and cap. Plus I may rent a code reader for it to see if that helps
Old Feb 4, 2010 | 11:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Wont kick over
Paperclip will read the codes. Look at the tech FAQ articles on main page.
https://www.thirdgen.org/service-eng...ht-error-codes
No better plug for these cars than a plain jane AC/Delco!
Old Feb 5, 2010 | 05:02 PM
Re: Wont kick over
Could the timing be off?
junior419
Apr 7, 2025 11:35 AM
L0tuS
Oct 4, 2015 08:07 AM
Giocio
Oct 1, 2015 12:20 PM
mcbitchman
Sep 29, 2015 12:32 AM
tattmann
Sep 27, 2015 05:20 PM
