Strange Fuel Pump issue
Old Feb 6, 2010 | 08:33 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
This happened a while back, and now I've finnaly gotten around to deal with it. Anyway, after driving for 45 minutes and shutting the car off I could not restart it. I stopped it and just shut it off like any other day. Then tried to move it 5 minutes later and it would not start. I noticed there was no fuel pump prime. Engine just cranks. I let it sit for about 1/2 hour then it started up again and ran fine. I drove it back home for another 45 minutes no issues. Stopped in front of the Garage and shut it off. Went to start it 5 minutes later to move it in the garage and the same thing happend. no fuel pump. the car barely ran and stumbled up the driveway. I have a Code 33 and Code 34 hard set. The Pump does not have a lot of miles on it, and it sounds fine when it's running. It never stalls out, it just won't start again if I shut it off.
Old Feb 6, 2010 | 09:04 AM
Vader's Avatar
Re: Strange Fuel Pump issue
Make sure the pump relay is powering the pump. It sounds as if the pump may be getting power through the oil pressure switch only and there isn't adequate oil pressure while cranking the hot engine.
The 33 and 34 may also be relay issues, and all of those relays are mounted in the same location. Time to check wiring?
Old Mar 12, 2010 | 03:34 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Ok I went out today and did some trouble shooting. Weather is better. Anyway I have a hard code 34 set. I clear the code and it re-appears instantly upon start up. As per the Code 34 fault isolation, I disconnected the MAF and a 33 set. However I'm not entirely convinced the MAF has failed. With the car running I was able to disconnect the fuel pump relay and it stayed running. The MAF relay gets power via the fuel pump relay. Is it possible the MAF is failing due to lack of or intermittent power via the fuel pum relay? The wires are in very bad condition on that harness that plugs into the relay
Old Mar 12, 2010 | 04:38 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Wow. I'm really quite disgusted at how much a MAF costs. Thats robbery
The strange thing about this is, after I unplugged the relay the car still started an ran. I understand the oil press circuit provides power after ignition but how is it starting with no relay? Wheres the fuel pressure coming from?
Old Mar 12, 2010 | 07:16 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Oil pressure switch will provide power to the fuel pump when pressure reaches a certain point. Don't remember the exact number any more. This was done as a backup for the FP relay.
Old Mar 13, 2010 | 10:28 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Well I solved the Code 33 and 34. There was a bent pin on the MAF sensor. I must of bent it when the original problem occured and I disconnected it. Now I never did find anything concerning the original problem. It happened the last two times I had the car out, and after 45 or so minutes. Right now it's primeing normally upon ignition. The fuel pum relay is obviously working. When I had the issue of a no start it was after I shut the car off. It never stalled out on me. It was idleing fine. When I shut it, it would not start, or if it did it was sounding like a one cylinder idle due to lack of fuel pressure. Could my relay be affected by temperature?
Old Mar 14, 2010 | 07:29 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Electronics do not like heat.
Typically i've found that either the injectors are bad or the ignition module is bad in a hot no start situation.
Old Mar 14, 2010 | 09:55 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
The car runs fine. Untill I shut it off. Once it's off I can't start it back up untill it cools down. The ignition module has maybe 15000 Km's on it. I can drive around all day without trouble. Untill I turn it off. Then theres no pump prime and no fuel pressure at the rail. If I do get a start it's very, very unstable.
Old Mar 14, 2010 | 03:28 PM
DHo's Avatar
DHo
Car: 1986 Trans Am
Engine: Vortec V8 5.0L
It sounds like there is a fuel return line problem.. when you turn your car off the fuel in the line boils and vaporizes and there is an air pocket in the line. Then when you try and start it again it fails, until the system cools down and the fuel goes back to liquid form. I think it can be fixed with a new fuel regulator? Hope this helps
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
