Does upgrading your heads require a tune?
Car: 1988 GTA
Transmission: 5 Speed
If you put aftermarket heads on will it require a tune to idle, race, and drive properly? With my limited knowledge I am guessing you don't need a tune because the MAF meter measures the air coming in and adjusts the fuel accordingly.
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Does upgrading your heads require a tune?
i think you would just be able to reset the computer by unplugging the battery for while and let it learn by itself...not sure though
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
You will find MAF cars are more adaptable to changes, a custom tune will enhace the performance a bit....
ambainb
Apr 25, 2016 09:21 PM
