Vin Issue
Old Feb 8, 2010 | 01:11 PM
Junior F-body's Avatar
Car: 1986 Camaro Sports Coupe
Engine: 2.8L V6 MPFI
Vin Issue
Hey Guys. So new to camaro but not to chevy/gm products.
I recently picked up an 86 camaro and had issues with the vin so i went
to the registries office.(Canadian) and ran the vin. it came out fine.
But i would like to know why when i tried to insure it i had so many issues.
I've done quite a bit of reasearch and have found it quite odd to have a letter in both the 2nd and 3rd vin postition.
In my case 2BG506103GL******.
It is a 17 digit vin and i cant quite figure it out.
I know its canadian and was built in CA but have no clue what BG is.
Any one else have any ideas?
Old Feb 8, 2010 | 01:35 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Vin Issue
Sounds really weird.
1982-86 CAMARO VIN
Vehicle Identification Number Example: 1G1AP87H4CN100000
First Digit Nation of Origin: 1=USA, 2=Canada
Second Digit Division: G=General Motors
Third Digit: 1=Chevrolet, 7=GM of Canada('83-'88)
Fourth Digit: A=non-passive, B=automatic belts, C=inflatable restraint, F=Coupe
Fifth Digit Model: P=Camaro Coupe or Z28, S=Berlinetta
Six & Seven Digits Body Style: 87=Sport Coupe/Camaro,
Eigth Digit Engine: See Engine Codes Below
Ninth Digit is Check digit
Tenth Digit Year: C=82, D=83, E=84, F=85, G=86
Eleventh Digit Production Plant: N=Norwood,Ohio, L=Van Nuys
Last Six Digits increase by one with each car built at each plan
1987-92 CAMARO VIN
Vehicle Identification Number Example: 1G1FP2184NL100000
Fourth & Fifth Digit Body Style: FP=Camaro Sport Coupe, FS=Firebird, FW=Trans Am
Six Digit: 2=Hatchback, 3=Convertible
Seventh Restraint Codes: 1=Manual Belts, 2 or 3=Manual w/ Driver Air Bag, 4=Auto Belts
Tenth Digit Year: H=87, J=88, K=89, L=90, M=91, N=92
Old Feb 8, 2010 | 09:45 PM
Re: Vin Issue
This is the Exact reason i posted it. I found the template above but could not find anything to match my Vin. It is a Legitimate Vin so im not sure.
Old Feb 8, 2010 | 09:48 PM
Drew's Avatar
Re: Vin Issue
For some reason was the VIN number changed? That VIN number doesn't follow the standard GM convention.
Old Feb 8, 2010 | 11:03 PM
Re: Vin Issue
Ill be honest i have no idea. It has been registered in Alberta 2 times prior to me and i have no idea where it originated from. Any chance gm will be able to help?
Old Feb 8, 2010 | 11:12 PM
Drew's Avatar
Re: Vin Issue
Probably not. In some circumstances, local government can issue a new vin for a car... Like if it's stolen and then recovered and rebuilt. Gm wouldn't be able to help because that's not a GM VIN number.
Old Feb 8, 2010 | 11:16 PM
Re: Vin Issue
Interesting. I did notice on the Inside of the door a British Columbia Sticker with a Vin but no information for the car as to tire specs and such. Just a sticker. it is very likely that something of the sort has happened.
Old Feb 8, 2010 | 11:34 PM
Drew's Avatar
Re: Vin Issue
Take a look at this. You might also call your local DMV and see what they can tell you.
http://www.icbc.com/registration-licensing/VIN
Old Feb 9, 2010 | 07:21 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Vin Issue
If it has a provincial sticker or plate with a VIN number on it than it's a reissue.
There are ways to find the original VIN on the car if you know where to look.
Old Feb 9, 2010 | 10:02 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Vin Issue
Isnt there a marking on the front radiator crossmember with the VIN? Maybe under the black radiator support piece?
Old Feb 9, 2010 | 07:16 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Vin Issue
Hello Junior F-body!!
The only reason that you found a BC sticker with a VIN, is because it was a stolen recovery, and after 30 days ICBC pays, therefore if it is found, they own the car, and so that there are no hassles with the original VIN showing up as a stolen car, they re-issue a VIN. Your dash VIN plate should be missing also!! California does the same thing, I seen it with my own eyes on a first gen 1969 Camaro!! On the 1987 Camaro's, all major body parts have a sticker with the original VIN, look for it on your 1986, you may find it!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
TheTraut88
Sep 11, 2015 05:16 AM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Formula_88AE
Sep 3, 2015 01:47 PM
