which head bolts to seal?
Old Feb 23, 2010 | 03:54 PM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
Does anyone know exactly which head bolts go into the water jackets on the small block 350? I have the 87 one peice rear main but Im shure that makes no differance. I useally just seal everyone but this time I have brand new AFR heads and ARP bolts and I want to do it perfect.
Old Feb 23, 2010 | 03:58 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Re: which head bolts to seal?
Seal them all.
Old Feb 23, 2010 | 04:44 PM
Car: 87 iroc z
Engine: 358 tpi
Humm so all of them go into water jackets? I ask because ARP says to seal the ones that go in water jackets and use the provided lube on the blind holes.
Old Feb 23, 2010 | 08:38 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
With stock blocks almost ALL of them go into water except for possibly one or two on the upper side of the block deck, but those are unpredictable.
Seal them all.
They told you that in case you were running a non-stock block.
Old Feb 24, 2010 | 12:58 AM
Car: 87 iroc z
Engine: 358 tpi
Ok I see.. Thanks for the reassureance.....
Old Feb 24, 2010 | 04:03 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
There are about 3 or 4 that don't go into a water jacket. It's best to just seal them all.
Old Feb 24, 2010 | 05:32 AM
Car: 87 iroc z
Engine: 358 tpi
I will for shure and Im glad to see Iv been right all these years by sealing all the threads on my small blocks lol.... Thanks agin this forum is the very best I never fail to get great killer answeres!!!!!!
evilstuie
Jan 9, 2020 08:29 PM
355tpipickup
Aug 25, 2015 12:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
