Anyone hear of welding the slot on the vacuum advance canister to limit advance?
Old Feb 25, 2010 | 12:54 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Combo is below. I am getting to much advance from my distributer at part throttle cruise causing my car to surge. I run 24 degrees initial and 36 degrees total timing all in by 2800 rpm. I was playing around with the idea seeing as it's free for me since i have the welder to do it. That way i could save some coin on buying an adjustable canister. What are your thoughts?
Old Feb 25, 2010 | 12:57 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Re: Anyone hear of welding the slot on the vacuum advance canister to limit advance?
Go ahead and try it, what's to lose? If it doesn't work you'll have to buy an adjustable one anyhow.
Old Feb 25, 2010 | 01:46 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
yes, you can definitely do this. It's been done before. I've seen more than a few pictures of people doing this.
Old Feb 25, 2010 | 02:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Crane used to make a limiting cam that would let you limit the amount of vacuum advance more easily than welding and filing the slot. I haven't seen it in catalogs for a while though.
Old Feb 26, 2010 | 08:20 AM
Car: 91 Firebird
Engine: Turbo 355
That would be a good buy. I dug around a little bit but couldn't find anything. Apeiron, I run about 24 degrees initial and 36 total. I would want to limit the vacuum advance to 10 degrees +/- above idle at the initial total? That's what i'm understanding.
Old Feb 26, 2010 | 08:28 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
A lot of people weld them, which I have done, but now I prefer to drill and tap for a limiter screw. I'm good about getting the limit right the first time, but the screw is removable for future adjustment.
I also like to run a lot of initial advance (if no computer control), but it can be very hard on your starter unless you use an ignition kill switch for hot starting.
Old Feb 26, 2010 | 08:31 AM
Car: 91 Firebird
Engine: Turbo 355
I'm curious to how the screw adjustment works. Do you just take the canister off and drill a hole larger than the slot and screw it in???
Old Feb 26, 2010 | 09:12 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
What I do is just a limiter that screws in from the outside.
I have one picture of one where I grafted a GM HEI advance unit onto a Toyota distributor body. It was a 4 cylinder distributor so the amount of vacuum advance (travel) was far too much.
photo:
http://memimage.cardomain.com/ride_i...623_medium.jpg
Old Feb 26, 2010 | 09:18 AM
Car: 91 Firebird
Engine: Turbo 355
photo:
Ah i see. I'm running an old points style distributor without the points. Pertronix electronic ignition to take its place. I got the replacement canister that looks a little different than that. I would have to plug the actual slot somehow. I wonder is there is something else i could do besides weld. I don't want the slot to rust up or anything.
Old Feb 26, 2010 | 09:23 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Braze it instead
Old Feb 26, 2010 | 09:27 AM
Car: 91 Firebird
Engine: Turbo 355
Braze it instead
I've never heard of that term before? Braze? Might be a stupid questions but I'm always up for learning something new.
Old Feb 26, 2010 | 09:39 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
http://en.wikipedia.org/wiki/Brazing
Old Feb 26, 2010 | 10:05 AM
Damon's Avatar
If you want 12* max vacuum advance you want to leave about 1/8" of travel in the arm. I just take some fairly thin plate, cut it as wide as the arm on the canister and zap it on the edges with the welder to hold it in place. That way you can easily break the welds and move it around or take it off.
I was thinking of making my own kit with an adjustable version of this basic idea that's screwed down instead of welded on to allow for adjustability.
Old Feb 26, 2010 | 11:47 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Cheap and easy.
http://www.summitracing.com/parts/PRO-66952C/
Old Feb 26, 2010 | 12:24 PM
Car: 91 Firebird
Engine: Turbo 355
Very good idea Damon! I think this is the route I'm going to go. Does that 1/8" of travel work for the points style canister? Or is that HEI? I'm not sure of the differances.
Old Feb 26, 2010 | 12:32 PM
Car: 91 Firebird
Engine: Turbo 355
Originally Posted by 3rd gen Will
I have the points style dizzy, not an HEI. I'm running the Pertronix electric ignition w/ revlimiter in place of the points.
Old Feb 26, 2010 | 01:10 PM
Sorry, go with this one then.
http://www.jegs.com/i/Accel/110/31034/10002/-1?CT=999
Frozer!!!
Jan 19, 2024 04:55 PM
Glowsock
Jan 9, 2017 04:06 PM
db057
Sep 4, 2015 07:57 AM
billybob6110
Aug 30, 2015 02:47 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
