Try to solve this one boys.
Old Feb 26, 2010 | 11:20 AM
jmat2407's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Ok got a 1989 Trans am with a 5.7/700r4 combo thats being a major PITA.
In drive or overdrive, you can mash the throttle yet the rps will only climb to about ~2600 SLOWLY and no higher.
However, if I manual put the car in first, itll rev/pull all the way up the tach, same as if I put it in 2nd. Once I bump it up into drive though, I get nothing over about 2600 rpms.
If I start out in drive and step on it, it will shift threw all the gears at pretty low speeds but itll never take off quick or go over 2600 rpms like I said.
Btw the car has brand new..
cap/rotor
plugs/plug wires
ignition coil
ignition module
ignition coil pick-up
fuel injectors
Yes the throttle is opening up 100% and the TPS is showing 4.5 volts at WOT, this is also supported by the fact the car runs by manually putting it in 1st and 2nd. WTF is up with my D and OD?
Old Feb 26, 2010 | 11:32 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: Try to solve this one boys.
This sounds like a trans issue not an engine issue since it doesn't do it in all gears.
Old Feb 26, 2010 | 12:33 PM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
I agree. Sounds like your 700r4 is due for a rebuild.
Old Feb 26, 2010 | 12:37 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Agree one more time, sounds like the govenor in the trans is sticking, or maybe a sticking solenoid, either way, time to take that out and have a rebuild done on it.
Old Feb 26, 2010 | 12:49 PM
gunner1204's Avatar
Car: 1987 Camaro Z28
Engine: 355c.i. Carb.
Transmission: TH350
I got a 700r4 that the OD went completely out in i can manually shift from first to second and it works fine but when i shift into D the engine whines up and i get no pull. I pulled the governer and it was fine no missing splines.
Its just those trans I suspect I stick with TH350's in everything I build
Old Feb 26, 2010 | 12:54 PM
jmat2407's Avatar
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Thats the thing though, the engine isn't even whining up when I floor the gas in D or OD. Ever if I floor it and hold it there it only goes up to about the 2600 and slowly picks up speed from there. Its the weirdest thing i would think if D or OD was busted the motor would still be able to rev up just not hardly go anywhere?, and supposedly the PO had just got the trans rebuilt not long before I bought it.
Old Feb 26, 2010 | 01:04 PM
Engine: L98 494hp
well, if the car is in third or fourth gear it will bog the motor and feel slow. you said it works good in first or second because the itt's in the correct gear. If it's staying in third or overdrive it won't rev up because of the gear it's in.....still sounds like a trans problem....take it to a trans shop and have them look at it....they'll be able to tell ya and should maybe diagnose it for free, some shops do.
Old Feb 26, 2010 | 02:16 PM
gunner1204's Avatar
Transmission: TH350
If the engine idles well and doesn't sound like it has problems and will rev up in park then I agree I think it is the trans not shifting right check your linkage 700r4's have the adjustable cable near the carb the teeth that held mine in place stripped out and it wouldn't hold the cable where i needed it. I would adjust it over and over again if that doesnt work diesel fuel and matches will take care of the problem.
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
Giocio
Oct 1, 2015 12:20 PM
db057
Sep 4, 2015 07:57 AM
CORV3TT3
Aug 23, 2015 11:26 AM
