Mini starter bendex pulls out during acc.
Old Mar 1, 2010 | 06:56 AM
84 camaro z28's Avatar
Car: 84 camaro z28
Engine: 5.7 carbed
Transmission: turbo 350
My Mini starter clears perfectly when the car isn't on. When I start the engine, it turns over real smooth and quite, yet when I put a little load on it the bendix seems to pull out closer to the flexplate. Does it especially in reverse. Any solutions/fixes I can do to this, have looked throught the forums without much luck. Thanks
Old Mar 1, 2010 | 07:41 AM
Damon's Avatar
Re: Mini starter bendex pulls out during acc.
Wait........ what??
Your starter is engaging the spur gear with the flexplate teeth when you put the can in gear? Like it's halfway engaging and grinding? Am I understanding correctly?
Old Mar 1, 2010 | 02:08 PM
supersquirrel's Avatar
Car: 89 IROC
Engine: 355 Super Ram, Dart Pro 1s
Transmission: 6 Speed
Axle/Gears: 4.11
Old May 7, 2010 | 09:07 AM
Car: 84 camaro z28
Engine: 5.7 carbed
Your were correct, but I believe the problem is with the torque converter. See once upon a time I accidentally put manual bolts in with out noticing then I tighten them all the way and drove them in the torque converter, thus bending the tabs. So I believe that is my problem.
Old May 7, 2010 | 11:33 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
So then the starter gear isnt moving at all but the flexplate is being pulled back?
Old May 26, 2012 | 12:14 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Sounds like you have bigger fish to fry than your starter...
EDIT: Whoops! Sometimes when reading through searched threads I forget to check dates
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
milk
Aug 10, 2015 06:26 PM
