How much of a gain with long tubes?
Old Mar 2, 2010 | 05:09 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
I was wondering how much of a gain will i get if i switched from shorty 1-5/8" primary to long tubes 1-3/4" or 1-7/8"?
I'm running a 383 forged with XE284 comp grind with 700 holley DP, Weiand stealth intake, 1" carb riser
Thanks, Chas
Old Mar 2, 2010 | 07:17 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: How much of a gain with long tubes?
You most likely will pick up horsepower just by going from a 1 5/8 to a 1 3/4" primaries. Going to the long tubes will pick up your torque.
Old Mar 2, 2010 | 08:52 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
would i be better off getter some large primary shortys instead? with my motor setup im going to make more torque than hp so to even the 2 out i need more hp....
Old Mar 2, 2010 | 10:45 PM
Car: 1989 GTA
Engine: 369 TPI
From the test I did and what others have observed with a good set of shorty headers such as what Dyno Don puts out there will not be much difference in horsepower from peak torque on up when compared to long tubes. Long tubes do better below peak torque. One of the problems is finding a good set of shorties.
Old Mar 5, 2010 | 01:58 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Ya that is my dilemma. Im looking to make better higher rpm hp numbers because i have a lot of low end torque that i dont mind sacrificing.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
z 28 jari
Sep 14, 2021 10:03 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
SG91camaro
Sep 5, 2015 10:27 PM
