350 build
Old Mar 2, 2010 | 06:11 PM
RussC's Avatar
350 build
well i just bought a spare 350 for my 89 gta and am going to do a full build up on it. i'm woundering if i should stay with the tpi set up or switch to a carb. i'm looking for the most hp i can get.
Old Mar 2, 2010 | 06:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The most horsepower you can get would most likely make the car undriveable on the street.
What are your real goals?
A carb is not legal for street use in any of the 50 United States. Regardless of how it is enforced where you live.
Old Mar 2, 2010 | 06:55 PM
RussC's Avatar
Re: 350 build
i'm in canada and don't plan on going south with it, so a carb is fine.
car will mostly be a track car and once in a blue moon to work. so 4-500 hp would be nice. down the road a year or 2 i plan on getting a supercharger.
Old Mar 2, 2010 | 07:33 PM
five7kid's Avatar
Okay, more information. Good.
Track car, carb. 500 HP, difficult with an NA 350. 400 a lot easier.
Heads. Power is in the heads. Get good ones, build the rest of the combo around them.
Supercharger will either require a complete rebuild of what you did NA, or you'll have to make compromises with the NA build.
Old Mar 3, 2010 | 09:36 AM
RussC's Avatar
Re: 350 build
these are the heads that i'm planing on using, Airflow Research 0992 - AFR 180cc SBC Eliminator Street Heads
i'm not sure what intake that i'm using yet, ideas would be welcome.
i'll be chatting with the guys at my local shop about some of the other parts so i'll post what i come up with after
Old Mar 3, 2010 | 11:25 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Re: 350 build
https://www.patriot-performance.com/...ome.php?cat=69
Just go buy a crate engine and be done with it. You'll easily spend $5k building a 500hp engine considering the heads you'll need plus crank/rods/pistons.
Old Mar 3, 2010 | 11:35 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: 350 build
You might wanna re word that before the flaming happens.
Old Mar 3, 2010 | 03:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 350 build
Russ - What province are you in ? Knowing your EXACT location might be helpful eh?
Get the 195cc heads if you want that HP level. 180cc is more drivable, but based on what you're doing, 195cc heads won't hurt you.
Putting a stroker kit in it while rebuilding it is CHEAP HP. An AFR headed 383 with an aggressive roller cam can be an easy 425HP.
Old Mar 3, 2010 | 11:38 PM
five7kid's Avatar
Re: 350 build
Flaming?
Since the OP didn't reveal he lives in Canada, or what he intended to do with the car, it was a valid statement.
Old Mar 3, 2010 | 11:39 PM
five7kid's Avatar
Note everything (small block) over 350 HP is a 383.
Old Mar 4, 2010 | 06:36 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Re: 350 build
Flaming?
So when someone on the board now says my 1983 camaro came stock with a quadrajet how are carbs illegal in all 50 states ...
Old Mar 4, 2010 | 07:25 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Re: 350 build
Yep. I suppose they just choose to mainly build 383's. 500hp for $5300 isn't too bad.
Old Mar 4, 2010 | 07:35 AM
RussC's Avatar
Re: 350 build
what fun would be in a crate engine? to me it's as much fun to build a motor for a car as it is driving one.
Old Mar 4, 2010 | 09:09 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Re: 350 build
Based on personal experience I agree it's fun building an engine, however when you find out you could have gotten more hp for the same money or less you end up a little disappointed.
Old Mar 5, 2010 | 09:01 AM
morepowerjoe's Avatar
Car: 86 Camaro
Re: 350 build
I have to agree, proven combonations, warranty, knowing exactly what to expect is money well spent. When you completely price out the money your going to spend doing it yourself, you'll quickly see it adds up real quick. But if you have the dough, go for it.
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
