383 Stroker Flexplate?
Old Mar 4, 2010 | 04:51 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
Hey, i bought a 383 stroker motor from a guy and now im bout ready to drop er in the car. I have a th400 tranny to bolt up to it. My question is, is what do i need for a flexplate? Can i use a sbc 350 one? Or do i need to buy a special plate because the 400 crankshaft in the stroker build?
Old Mar 4, 2010 | 06:42 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: 383 Stroker Flexplate?
Is the engine internally or externally balanced?
Jake
Old Mar 4, 2010 | 07:12 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Check the damper on the front of the engine. If it is a weighted 400 damper, then you need a weighted 400 style flexplate.
If it's a neutral balanced 350 damper, then you need a neutral balanced flexplate.
If it's an aftermarket crank and is internally balanced, then you need neutral at both ends of the engine.
Old Mar 4, 2010 | 07:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
So long as his new engine is 2 pce seal crank; if it is newer 1 pce seal then he needs the correct ext balance flexplate
And if you have to run a 400 flexplate it will most likely be a 168 tooth so you may have to change your starter if you have one for a 153 tooth now
Old Mar 5, 2010 | 10:09 AM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
So how can i tell what kind of dampener i have?
Old Mar 7, 2010 | 08:44 AM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Still need help!
Old Mar 7, 2010 | 04:59 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Neutral balancer is perfectly round; front and back
400 balancer is cut away or has weight inside
http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories
http://cgi.ebay.com/ebaymotors/New-H...Q5fAccessories
Old Mar 7, 2010 | 05:41 PM
JakeJr's Avatar
Axle/Gears: 3.07
Externally balanced harmonic dampers/balancers have a counter-weight on the engine side of the balancer.
I read that at least one company sells a balancer with a removable weight so it can be used on either internally or externally balanced engines.
If you're still in doubt about what you have, stop by a machine shop and show it to one of the guys there. He'll tell you what it is.
Jake
Old Mar 8, 2010 | 11:58 AM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
They sell bolt-on counterwieghts for the internally balanced 350 flexplates. That is so you can reuse the stock 350 flexplate with a externally balanced 400 crank.
Check Summit, Jegs, Speedway.
Old Mar 8, 2010 | 11:33 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
This is the style balancer i have, so going off of that i need a 400 style flywheel? or a 350 with a weight?
Old Mar 8, 2010 | 11:53 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
I have a flexplate for externally balenced 383, It was bolted up between my 383 and 700r4 .
Old Mar 9, 2010 | 06:40 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If it is on a '92 1 pce seal engine, then it is only ext balance at rear; still neutral at front
400 is ext balance both ends
Old Mar 9, 2010 | 06:44 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Cheap fix and keep your stock internal balance 350 flexplate
http://www.summitracing.com/parts/QTI-RM-521/
Old Mar 9, 2010 | 07:47 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
It came off a two piece rms
Old Mar 9, 2010 | 10:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Don't confuse the issue. That has nothing to do with the OP's situation. It is also incorrect to state it as you did (the weights on a one-piece RMS flexplate aren't the same as a two-piece RMS externally balanced flexplate).
Old Mar 9, 2010 | 10:14 AM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
So i have a factory 350 flexplate layin in the shop, i can buy one of those wieghts and mount the two together behind my stroker motor, retain the starter i have and be done with it?
Old Mar 9, 2010 | 10:48 AM
five7kid's Avatar
Should be able to, as long as your torque converter bolts to it and starter mates with it. Is it 153 or 168 tooth?
Old Mar 9, 2010 | 01:20 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
I believe it is a 153 tooth, it came on a stock 350 block that i was going to rebuild. I have a starter to match it like i said as well.
Old Mar 9, 2010 | 01:50 PM
five7kid's Avatar
Trucks typically had 168 tooth flexplates, for what that's worth.
Sorry if I didn't read all your posts thoroughly. Been having to do a lot of speed reading on TGO lately.
Old Mar 9, 2010 | 03:34 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
So is there a difference between the 168 and 153 tooth other than the starter?
I guess im gunna have to go out and start counting
Old Mar 9, 2010 | 07:45 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Just meaure flexplate
168 is 14" dia ; 153 is 12 1/2"
Old Mar 9, 2010 | 07:54 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Never said they did.
Just clarifing tyler92's statement that he had a ext balance flexplate because he has a '92 car and it may well have had the 1 pcs RMS balance because he did not state when posting that his 383 was 2 pcs.
Many do not correctly understand the balance setup on the 1pcs RMS engines
Old Mar 9, 2010 | 08:55 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
What year was your block? maybe I missed that.
Is it a one-piece or two-piece rear seal?
Old Mar 17, 2010 | 11:31 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
I dont know the year of the block, I can provide the casting numbers if that helps...
And I also dont know if its a 1 piece rms or 2 piece...
But here is a picture of my harmonic balancer, if this helps any let me know what ill be needing for a flexplate.
Ill run out in the shop and get the casting numbers and post those up asap as well, thanks for the help, and keep it coming :]
Old Mar 18, 2010 | 12:01 AM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Somebody out there has to know what ima need?
Old Mar 18, 2010 | 02:00 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Old Mar 18, 2010 | 02:27 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I think you need the larger diameter weighted flexplate - flexplate for a stock 400.
You really need to look at the backside of your damper. It should have a section cut out on the backside part-way around the outer ring.
I see the holes drilled on the front side, which is why I assumed it's a 400 damper and why I said I think you need the weighted 400 flexplate.
Your rear crank flange is the older style that used 2-piece rear seal.
A stock 400 damper looks like this on the back:
http://www.partzfinder.com/PhotoDeta...ode=PIO-872004
You can see part of it is cut away.
Old Mar 18, 2010 | 04:42 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
305sbc: I for sure have a 400 balancer if thats one in the picture, mine is exactly the same as that...
Now what do you think i need to get?
Old Mar 18, 2010 | 06:21 PM
five7kid's Avatar
I don't believe that's a 400 damper. Those holes look like standard balancing drilling, not counterweights.
You definitely have a 2-piece rear main seal block/crank. Since you'll be using a TH400, the standard factory 168-tooth 400 externally balanced flexplate should be fine, as long as the starter doesn't get in the way of your headers (shouldn't).
Old Mar 18, 2010 | 06:22 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As 305sbc states above , you need a 400 flexplate which will probably only be available as a 168 tooth
Old Mar 18, 2010 | 07:22 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Well I have 2 flexplates layin in the shop, ill go down and take some pictures of them tonight and maybe someone can identify them for me; hopefully I got one that I can use.
Old Mar 18, 2010 | 09:21 PM
five7kid's Avatar
Unless they came off of a 400 SBC or 454 BBC, they won't be the right thing. You'll either need to get one (they aren't too expensive), or get one of those weights that bolts between the crank flange and the flexplate.
Old Mar 18, 2010 | 11:05 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
If id get one of those weights that bolts between would I be able to use a stock unweighted 350 flexplate?
Im just wondering if the size of the hole for the crank is any different going from a 350 to a 400.
Old Mar 18, 2010 | 11:24 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
i will take a pic of what i have , and you can see if its what you need
Old Mar 19, 2010 | 09:27 AM
five7kid's Avatar
That's the idea. And, no, there is no difference in the crank flange or attach bolts between a 2-piece rear main seal 350 and a factory 400 crank.
Old Mar 19, 2010 | 10:50 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I checked my damper collection last night and my 400 damper has the holes drilled on the front, on the same side that the weight is cut away on the rear.
One of my non-400 dampers had a couple of extra holes drilled in the front, all of the others have no extra (offset) holes drilled.
I know there is an aftermarket weight for the rear crank flange to allow you to use a neutral balance flexplate, but I always just use a 400 flexplate or go internally balanced via crankshaft modification.
I think the 400 flexplates are pretty cheap.
A company called Renegade sells it for $35 through Motorville in Lenexa Kansas.
Old Mar 19, 2010 | 04:40 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Well I went down in the shop last night and took some pictures of what I got, im not exaclty sure of what they are tho...
This is a weighted flexplate that I got from a buddy. Its 14 inches wide with a 2 inch center hole.
This is a non weighted flexplate that I took off of a project 350 motor I had. It too is 14 inches wide but it has a 2 1/2 inch center hole.
Old Mar 19, 2010 | 09:32 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
The top one is externally balanced and the bottom is neutral balanced.
You have a 69-72 chevy 350 block according to the casting number so you then have a 2 piece rear main seal so you then need a internal balanced (neutral balanced) flywheel/flexplate.
Old Mar 19, 2010 | 10:44 PM
carscomefirst's Avatar
Car: 04 gtp, 96 f150, 88 camaro
Engine: 3.8sc, 5.0, 385ci
Transmission: auto, 5speed, 700r4
The best thing to do is contact the person you bought the motor from and ask if it is internal or external ballance. This is the Only way to know for sure what you need.
Old Mar 20, 2010 | 03:20 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The top one is off a late model 1 piece RMS engine; ext balance at REAR only / neutral at front .
Note smaller PCD of crank bolt pattern compared to early model 2 pce seal one at bottom
Not if he has a 400 stroker crank as noted above.
Needs correct 400 only flexplate
Old Mar 23, 2010 | 11:13 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
a couple of my damper pics:
http://s702.photobucket.com/albums/w...art%20weights/
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
