BEST IGNITION SYSTEM
Car: Z-28
Engine: 355
Axle/Gears: Stock
Folks.. i had it with my mallory base ignition system... I am going with MSD... I am looking for the complete set, distributor, coil, wires and CD-BOX... I have an 87 camaro, no computer, a GM ZZ3 create engine. CAN ANY BODY RECOMEND ME A MSD SYSTEM? THANKS!
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 355 SBC
Transmission: TH350 with 3500 stall
Axle/Gears: GM 12-bolt with 4.10 gears
Re: BEST IGNITION SYSTEM
I'm using a MSD 6-ALN along with a pro-billet dizzy and blaster 2 coil. It's basically bullet-proof and the rev limiter is great.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I've got the Digital E-curve distributor from them with a Blaster SS coil. No problems at all. The nice thing about the E curve is having the adjustable rev limiter built in and chainging the curve by just adjusting dials.
Transmission: 4L80E/4L80E
Simple: MSD 8362 ready-to-run large cap HEI. $130 from Summit.
More complicated: MSD8361 small cap vacuum/mechanical advance distributor, 8207 Blaster SS coil, 6A box.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Car: 1986 Irocz
Axle/Gears: 3.25:1
Distributor: MSD 8361
Coil: MSD Blaster-3 MSD 8223
CD box: MSD 6AL MSD 6420
Did you mean 8362 for the HEI?
I prefer the square type, can mount in anywhere, less susceptible to heat when mounted away from the intake manifold.
Rev limiter is of limited value (no pun intended) on the street. Save $30 and get the 6A box.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
My setup, expensive, but worth it to me. Can't wait to get it all installed.
My cars plans: Drift (mainly), Drag, Street, Auto-X, Gymkhana etc. EVERYTHING OUT THERE, so I want as much adjustability and tuneability as possible, in which I won't get into what I want for my suspension. This towards the need for a rev limiter as questioned by the previous poster.
Ignition: #6420
Coil: #8226
Distributor: #8366
Spark Plug Wire Set: #31839 (ACDelco Rapidfire Spark Plugs)
Harness: #8876
Alternator: #5111
Kit: #5158
Pulley: #5190
Starter: #5095
P.S. Take that old school guys and your Mallory only for my Camaro BS...haha. J/K
Ignition: #6420
Coil: #8226
Distributor: #8366
Harness: #8876
Alternator: #5111
Kit: #5158
Pulley: #5190
Starter: #5095
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
